Author Topic: Trouble disassembling/separating PT 89 Race pipe  (Read 5591 times)
Offline All250R
« on: May 31, 2022, 11:26:19 AM »
Guys,
I think years ago I put some RTV in the joint that separates the header from the main body. I'm trying to get the pipe off the bike, but I cannot get the two sides separated. Any tips? I'm short of taking a sawzall to it...
Jason
Re: Trouble disassembling/separating PT 89 Race pipe
« Reply #1 on: May 31, 2022, 12:21:24 PM »
Hi Jason, try some heat and a strap wrench.
« Reply #2 on: May 31, 2022, 02:09:03 PM »
Kroil penetrating oil/solvent works great on RTV. It also helps with rusted/crusted metal on metal connections. Spray some on and let it sit for a while then go after it with the strap wrench like Joe suggested. Heat will also work to break down the RTV.
Loren
« Reply #3 on: May 31, 2022, 08:52:48 PM »
Whatever you do, please don't take a sawzall to it. You'll eventually get it off but you should also be proud of the fact you had that sucker sealed up good. Mine usually leak
Offline All250R
« Reply #4 on: June 02, 2022, 02:57:46 PM »
The strap wrench did it before I had to apply any heat. Thanks Joe. I applied some pb blaster, though not sure how far I got it into the joint.
Let me know if anyone is interested in trading for a not-rusted trx9 pipe.
