Author Topic: Cr 01 coil mount for 85 atc 250r.....  (Read 11810 times)
Offline Sweetchucky
« on: September 01, 2022, 08:01:58 PM »
New member here....Looking for a way to get ahold of a coil mount for my 01 cr 250 coil...Trike is an 85 atc..
Re: Cr 01 coil mount for 85 atc 250r.....
« Reply #1 on: September 05, 2022, 05:52:52 AM »
Looks like you’ll have to make one.
What size is the atc frame tube?
Offline BENCH
« Reply #2 on: December 18, 2022, 04:50:25 PM »
In the same boat.  BDT made them in the past but nothing at the moment.  I am working on a bracket now for my '85.  Will post some pics once done.
Offline atvmxr
« Reply #3 on: December 19, 2022, 10:19:46 AM »
the coil or the cdi?
Offline BENCH
« Reply #4 on: December 23, 2022, 07:46:50 PM »
coil
Offline BENCH
« Reply #5 on: January 12, 2023, 01:51:33 AM »
Used an ESR clamp. Ditched the square top and opted for an insulated clamp. I had to shorten to length but seems to clamp tight. Will add a small screw if it rotates but I'm gonna give it a try.
« Reply #6 on: January 30, 2023, 12:47:54 PM »
You've now ISOLATED the coil.......so you will have to add a grounding strap from the aluminum mount to your motor or you will not get a spark.
Easy fix!
Offline BENCH
« Reply #7 on: February 06, 2023, 11:58:45 PM »
Easy fix!
Correct.  I added one during final assembly.  These were taken before test fitting the tank and routing the wiring harness.  Made one trip to Glamis with this system and worked well, no issues.
