Author Topic: DMR Toyger cylinder  (Read 19577 times)
Offline atvmxr
Re: DMR Toyger cylinder
« Reply #15 on: February 22, 2024, 09:43:46 AM »
yes, they rip!  raced against them last saturday.  Im hopefully getting one in a few months
Offline 88trx
« Reply #16 on: February 22, 2024, 02:13:57 PM »
what is the update about actually being able to buy on of these cylinders?
« Reply #17 on: February 28, 2024, 05:16:54 AM »
My understanding is 2025.
« Reply #18 on: May 17, 2024, 04:14:28 PM »
Sharing about availability but it doesn’t look like you’ll be able to buy the cylinder by itself.  Hopefully that changes by the time they are released to the general public.
« Reply #19 on: September 04, 2024, 06:16:12 PM »
From the sounds of it now the cylinder will be available to the general public.
« Reply #20 on: September 06, 2024, 01:14:32 PM »
I’m still a little confused if a person will be able to buy this cylinder and build it yourself….
Offline Michael88R
« Reply #21 on: September 06, 2024, 01:26:57 PM »
I think DMR has to build it and it has to have all the parts listed.  Probably be $6-7k
« Reply #22 on: September 07, 2024, 09:38:29 PM »
His big me-little you bdt attitude is a huge turnoff lol. I’ll definitely keep my builds going to Pete! A new innovative cylinder for our community is a welcome thing. It’s too bad you have to drink the koolaid or you don’t get one.
Offline Michael88R
« Reply #23 on: September 08, 2024, 01:40:48 AM »
Agree 100%.  “It’s the best cylinder ever, but you can’t have it!”
« Reply #24 on: November 20, 2024, 07:42:47 AM »
From davemooreracing.com
Parts Needed
TOYGER Top End kit $1995 (DMR Only)
Billet Bottomend Kit $2304
(Includes Center cases, Clutch cover, Stator cover, Water pump cover, Water pump, Kick starter shaft)
DMR will NOT use any other cases or covers.
38mm Air striker (new or used in good shape) DMR machining for carb $80
HotRods long rod crank(new) $355.26
Zeeltronic ignition complete ( Weston Rainwater drwperformanceatv.com) $595
Billet clutch basket(new) (from hinsonracing.com) $284.99
Bearings, Seals, Gaskets $195 DMR only
Bolts, Studs, Dowl pins $62 DMR only
SMR pipe (Scott Moser Racing) estimate- $600
Case saver (Weston Rainwater DRW) $83.99
All internal parts(gears, Shafts, spacers, clips, shift drum, forks, fork shafts, Counter balancer, crank gears, Kick stater gear and all other parts. All parts will be inspected)
Steel kick starter
Labor including (assembly, break in, dyno tune) $620
Return Shipping TBD
So.....this gives a grand total of this complete package of: $7175.24 ......;)  That's quite the package.
« Last Edit: November 20, 2024, 07:44:50 AM by Langbolt »
