Author Topic: ESR cases  (Read 13039 times)
Offline chrisr
ESR cases
« on: August 15, 2013, 10:36:28 AM »
Anybody got a set of ESR cases?  Just curious about them and looking for a little feedback.  At the price listed on their website I'm tempted to buy a set and put on the shelf.
ESR cases
« Reply #1 on: August 15, 2013, 10:42:42 AM »
Curious also,if anyone has them here we will get honest feedback. I THINK I read on here that someone said no issues at all,if so that is a great thing!!
Offline Fear250r
ESR cases
« Reply #2 on: August 15, 2013, 11:31:18 AM »
My cousin (rough250r) has a set. Hopefully he'll chime in. Been way too busy lately and haven't had much time to take s look at them.
In house hybrid ball buster
Offline WFO370
ESR cases
« Reply #3 on: August 15, 2013, 03:16:32 PM »
I bought a set of the tall cases about 5 months ago and have had no problems with them.
ESR cases
« Reply #4 on: August 15, 2013, 04:19:32 PM »
Quote from: WFO370;8631
What stroke crank are your tall case's made for?
ESR cases
« Reply #5 on: August 15, 2013, 04:41:51 PM »
Sorry to bring it up but .net had quite a few replays about the cases. Deck height and center gaskets, counter balancer bore not round, just a couple off the top of my head.
Someone else mentioned that a racer at an event had a full ESR motor cases included. Said he ran good, when it ran and did not complete weekend.
This is just what I have read on the forums.
ESR cases
« Reply #6 on: August 15, 2013, 05:02:07 PM »
Quote from: Hawaiiysr;8647
Sorry Josh, this site does not want biased information. We really don't care what Carlos had to say about them. Were looking for members who have had experience with the new cases. Thanks Tony
Offline WFO370
ESR cases
« Reply #7 on: August 15, 2013, 05:27:31 PM »
Quote from: etccb;8644
My crank is a 5 mil. I believe that the tall cases just eliminate having to use the spacer plate. So I don't think the tall cases can be used with a short rod crank.
ESR cases
« Reply #8 on: August 15, 2013, 05:36:05 PM »
That is the info that I was looking for and I have a question for you. Did you do the engine build yourself? Did you use an oem center case gasket and threebond liquid gasket in the tall base section or what did you do for a center case gasket?
« Last Edit: August 15, 2013, 06:10:44 PM by etccb »
Offline WFO370
ESR cases
« Reply #9 on: August 15, 2013, 06:17:23 PM »
The motor was put together by a local builder and all the gaskets were factory oem.
ESR cases
« Reply #10 on: August 15, 2013, 07:21:04 PM »
Cool. Probably the as recommended oem plus for center gasket. Thanks.
Offline rough250r
ESR cases
« Reply #11 on: August 16, 2013, 06:54:38 AM »
I have a set of the new ESR cases.. for the most part they are pretty good.. I give them a 8 out of 10. The nice thing about them is that you can buy them with a while bearing kit pressed in and ready to go. You do have to alter the cavity for the counter balance a bit to get it in and able to spin freely but that's the only problem for the most part.  The finish is a little bit rough..it just kind of looks like the powder coater was in a hurry .. not a big deal really but just figured I'd mention it. Here's a pic of the new motor build.. should be up in about a month [ATTACH=CONFIG]1416[/ATTACH]
Edit I got the stock height cases but machined out for a 330 ..so I'll still be running a spacer plate
« Last Edit: August 16, 2013, 10:36:27 AM by rough250r »
ESR cases
« Reply #12 on: August 16, 2013, 08:01:29 AM »
What did u do you do to remedy the counter balance bore?
Tony, I respect .org and you. The issues I brought up was from other members. I did not have Carla in mind. Im Sorry if it came off that way.
Offline rough250r
ESR cases
« Reply #13 on: August 16, 2013, 09:25:38 AM »
I took a dremel  with a cone shaped grinding wheel and about 15 minutes of time... from what I remember it was only on one of the case halves that really needed touching up..
On a side note what island are you on hawaiiysr?  Oahu?
ESR cases
« Reply #14 on: August 16, 2013, 09:33:01 AM »
Yes sir I'm on Oahu:) I ride up kahuku, time allowing. Still recovering from a broken wrist so for the time being I'm a forum junky:excitement:
So you didn't have to take much off? I just don't like the idea of having to grind on a new set of cases or sending them out to a machine shop
