Author Topic: LSR Chassis w/ CR250 ignition + wiring harness pictures ?  (Read 6976 times)
Offline Justin4141
« on: February 08, 2024, 02:57:21 PM »
Does anyone have pictures of how they ran there wiring harness with a 01 Cr 250 ignition on a Lonestar chassis ? Looking to clean mine up an need ideas !
Re: LSR Chassis w/ CR250 ignition + wiring harness pictures ?
« Reply #1 on: February 09, 2024, 06:49:18 AM »
I don’t have a Lonestar but I’ll post a CR ignition being used with a Laeger.
I’ll get pics later today.
« Reply #2 on: February 10, 2024, 02:50:09 PM »
Starting with a CR kill switch.
« Reply #3 on: February 10, 2024, 02:53:53 PM »
Pumashine round tube coil mount.  CR cdi mounted where a trx coil would go using the CR rubber cushion.
« Last Edit: February 10, 2024, 03:01:12 PM by croat1 »
« Reply #4 on: February 18, 2024, 07:21:03 PM »
Offline atvmxr
« Reply #5 on: February 22, 2024, 09:40:26 AM »
I thought the pumashine coil mounts were discontinued?  Mine is a hot mess, held in place with zip ties.  coil where stock one is, cdi where stock one is.  but its made it through several MX and arenacross races.
I need to install my zeel anyway
« Reply #6 on: February 23, 2024, 09:57:37 AM »
If you can find an ESR coil moint they work great! I used mine along with a couple handlebar clamps to get it to mount up to the round tube of my LAEGER.
Offline atvmxr
« Reply #7 on: February 23, 2024, 01:09:57 PM »
can you snap a pic of how your rear shocl reservoir and hose is routed?   My LSR has a little cross brace by the front seat mount and its right in the way of my hose.  at least the way I think its supposed to be routed
« Reply #8 on: February 27, 2024, 12:26:48 PM »
Clever using the handlebar mount, I used to drill those ESR mounts and use a "u" bolt with threads to clear the round tube.
