Author Topic: Pipe choice questions....  (Read 4646 times)
Offline fx4pitrone
« on: August 15, 2013, 11:32:57 PM »
I have 3 pipes and need to decide which one to use....
ESR trx-6 pipe
PT Type 6 pipe
FMF pipe (can't remember which one exactly, Ill find out)...
Motor (stock cyl) will have a mid-range port...
I wand more low to mid range, and more torquier easier to ride power, but w/ good all around power.  Not concerned w/ much power up top, because the wood/trails we ride don't usually allow for that.  I want to be able to torque it up a rocky hillclimb w/ some technical spots and big rocks that I can't barrel over...
Which pipe will be my best bet?
And what is the trx-6 pipe best at?  I see it's no longer offered....
Thanks!
Offline Michael88R
« Reply #1 on: August 16, 2013, 01:19:30 AM »
I would go with the trx6.  It is an mx/woods pipe.  Not much different than the trx7 that they offer now.  The PT type 6 is strictly a woods pipe.  The trx6 would be better all around, but still have better low/mid than the other ESR pipes.  If you have a fatty pipe, the TRX6 would probably have better low/mid over it too.  Try the trx6.  If you still want more low end, then try the PT6.
« Reply #2 on: August 16, 2013, 08:08:36 AM »
I would start off with the trx6. I have never ran a pt type 6 myself but the trx6 has a large woods fan base. Go from there.
Offline fx4pitrone
« Reply #3 on: August 16, 2013, 09:17:22 AM »
Thank you for the replies... good to hear as I didn't know the trx6 was a mx/woods pipe...I'll start w/ that one!!:smile-new:
« Reply #4 on: August 16, 2013, 09:51:13 AM »
You should let me try out that PT Type 6 :)
Offline Rupp250
« Reply #5 on: August 16, 2013, 10:10:11 AM »
Try them all and see which one you like to ride with the most......
DUNER -86 250R  Flinstone
Offline fx4pitrone
« Reply #6 on: August 16, 2013, 10:47:42 AM »
Haha Tbone maybe... if this trx6 pipe is the ticket, it may be up for sale!
