Author Topic: 8 plate clutch  (Read 3189 times)
8 plate clutch
« on: November 12, 2024, 04:06:00 AM »
OEM parts modified to run 8 plates.  Fits under the stock cover.
Re: 8 plate clutch
« Reply #1 on: November 12, 2024, 08:02:30 AM »
Hey Joe, Is there a write up on how this is done ? :)
Re: 8 plate clutch
« Reply #2 on: November 12, 2024, 04:03:14 PM »
Arlan from Led: basically the inner hub  and Pressure plate are machined in order to accommodate the extra plate. Also, a thinner metal plate is used in the clutch plates. This is a mod that he does when he builds big bore engines, not sure if it is something that he will do alone.
