Author Topic: Round/Aftermarket Frame Coil Mount  (Read 10102 times)
Offline bushwesl
« on: February 14, 2025, 09:15:50 AM »
I’m trying to track down some pieces for my Arens frame swap.
I’ll need a round tube/aftermarket frame coil mount; does anyone have one that they’d like to part with?
Thank you,
Wes
Offline bushwesl
Re: Round/Aftermarket Frame Coil Mount
« Reply #1 on: February 14, 2025, 09:31:49 AM »
Actually, I just found this pic of what looks to be an ESR coil mount plate with a rubber strap to mount it to the frame. I already have the ESR OEM frame mount with plate, so I think I'll just try to find a rubber strap to mount it to the round frame.
Offline BENCH
« Reply #2 on: March 02, 2025, 03:21:31 PM »
I did that.  Works just fine.  Just make sure you run a separate ground.  Had to re-drill the hole in the hose clamp and shorten rubber isolator.
« Reply #3 on: March 31, 2025, 10:10:24 AM »
Wes, did you find one?
