Author Topic: QOTM June 2025 entry  (Read 10437 times)
« on: May 21, 2025, 02:33:13 PM »
THIS IS THE LAST QOTM I’M DOING
June 2025 QOTM entry. There will be no voting.  A winner will be chosen by a random number generator.
Winner will be chosen June 21, 2025.
Topic is anything goes:  ATC/TRX250R….a build, complete quad, riding picture, an Engine pic.  Fill out the list below or a short write up.  Once again anything goes but must have a 250R water cooled engine 1985-1989. Previous winners are eligible.
Enter now for the June 2025 QOTM   Winner will receive a $50 gift certificate from Rocky Mountain ATV.  I am sponsoring this so the gift  comes from me.  This is the official thread so post here.
Thanks everyone. Good luck fellas.
QOTM Rules
   1.   One post per QOTM entry (i.e. no multi posts for the same entry).
   2.   You may post multiple entries (e.g. if you own 2 250R's, you may make 2 separate posts).
   3.   If you win, PM for gift certificate
   4.   No blatant advertising or promoting.
   5.   QOTM entries only (i.e. no commenting back and forth - this helps keep the thread clean.
   6.   Fill out QOTM entry template below (copy and paste) or a quick write up.
Failing to comply with these rules may result in removal of QOTM submission.
   1.   Frame:
   2.   A Arms:
   3.   Swingarm:
   4.   Steering Stem:
   5.   Axle:
   6.   Carrier:
   7.   Locknut:
   8.   Hubs F|R:
   9.   Bars:
   10.   Brake/Clutch Lever:
   11.   Grips:
   12.   Foot Pegs:
   13.   Bumper:
   14.   Grab Bar:
   15.   Front Shocks:
   16.   Rear Shock:
   17.   Brake Lines:
   18.   Rotors F|R:
   19.   Rims F|R:
   20.   Tires F|R:
Body:
   1.   Plastic:
   2.   Graphics|Seat Cover:
   3.   Fuel Tank:
Engine|Drive System:
   1.   Cylinder|Head:
   2.   Bore & Stroke:
   3.   Displacement:
   4.   Carburetor:
   5.   Reeds:
   6.   Air Filter|Box:
   7.   Pipe|Silencer:
   8.   Clutch|Plates:
   9.   Gearing F|R:
   10.   CDI|Killswitch:
   11.   Cooling:
Other miscellaneous information.
For the drawing (in order of participation):
1.  All250R (Jason)
« Last Edit: June 05, 2025, 01:52:41 PM by croat1 »
Offline Michael88R
Re: QOTM June 2025 entry
« Reply #1 on: May 21, 2025, 11:19:49 PM »
QOTM is back!!!!!!   Good job Joe!
« Reply #2 on: May 22, 2025, 01:11:56 PM »
Thanks Michael.  I try to do good.
« Reply #3 on: May 27, 2025, 11:35:15 PM »
Now let’s get some folks to enter!!
« Reply #4 on: May 28, 2025, 04:01:32 PM »
All my stuff is broken projects. :(
Offline All250R
« Reply #5 on: June 05, 2025, 01:30:50 AM »
I'll bite!
This is my frist 250R that I still fathfully ride, purchased in 2002 for $5k. It also helps me with product testing. Below is the current configuration.
   1.   Frame:                           88 OE/Honda
   2.   A Arms:                          Roll Design
   3.   Swingarm:                     88 OE/Honda
   4.   Steering Stem:              88 OE/Honda
   5.   Axle:                              RPM Dominator w/race hub
   6.   Carrier:                          RPM tapered bearings
   7.   Locknut:                        Modquad
   8.   Hubs F|R:                     89 OE/Honda
   9.   Bars:                             Renthal 615-01 - I believe the best bar upgrade
   10.   Brake/Clutch Lever:    rear: stock, front: ASV, clutch: All250R custom for magura v167 hydraulic
   11.   Grips:                          Pro Grip 699 gel “super bike”, twist throttle, hardness sh:35
   12.   Foot Pegs:                  Roll Design
   13.   Bumper:                     88 OE/Honda
   14.   Grab Bar:                   PRM
   15.   Front Shocks:            Custom Axis, x3 adjustable
   16.   Rear Shock:               Custom Axis, x3 adjustable
   17.   Brake Lines:               Galfer
   18.   Rotors F|R:                OE|EBC
   19.   Rims F|R:                  Douglas Blue, Hiper
   20.   Tires F|R:                  Skat Trak
Body:
   1.   Plastic:                         88 OE/Honda
   2.   Graphics|Seat Cover:  88 OE/Honda, Costmic Quads circa 2007
   3.   Fuel Tank:                    IMS
   1.   Cylinder|Head:             85 cyl, 97 CR piston, All250R head
   2.   Bore & Stroke:             68x72
   3.   Displacement:             262cc
   4.   Carburetor:                  38 Keihin PWK (non-AS)
   5.   Reeds:                         V-force (CR250R)
   6.   Air Filter|Box:               K&N w/Outerwear (sand), TwinAir w/Outerwear (dust), All250R bracket
   7.   Pipe|Silencer:              ESR TRX9
   8.   Clutch|Plates:              OE/Honda
   9.   Gearing F|R:               13/37 Sunstar, DID non-oring chain
   10.   CDI|Killswitch:           OE/Honda, All250R 89 harness
   11.   Cooling:                     Afco doublepass, Samco (uk) hoses
« Last Edit: June 05, 2025, 01:45:57 AM by All250R »
« Reply #6 on: June 21, 2025, 09:46:03 AM »
Jason, you win.  Pm your email please.
Thanks
Offline All250R
« Reply #7 on: June 23, 2025, 03:26:15 AM »
Sent. Thanks Joe!
