Author Topic: Rear caliper mount  (Read 14035 times)
Rear caliper mount
« on: February 02, 2026, 01:22:45 PM »
JJ’s Machine 86-89 Trx250r rear caliper mount
Re: Rear caliper mount
« Reply #1 on: February 03, 2026, 07:41:54 AM »
Hey Joe, I reached out to him and suggested he offer a mount like that , that would incorporate the 250R caliper mounting holes....BUT would use a NEWER Nissan caliper from the HONDA CRF Front Caliper. Like the Swap I did years ago....It's a Twin Piston Caliper with no Emergency Brake.....I have not heard back from him.....
Here's the old post for reference
https://www.forums.trx250r.org/index.php/topic,2591.60.html
:D
« Reply #2 on: February 03, 2026, 05:58:14 PM »
John, that would be an ideal setup utilizing a dual piston front caliper.
« Reply #3 on: February 07, 2026, 05:17:47 PM »
Joe,
This pic shows how close the CRF Caliper mount is to the TRX Support.....it's off by 1/4"
So, either supply a NEW Steel Support....which I have made out of Stainless.
Or supply a NEW Caliper mount to adapt to the TRX support.
Offline All250R
« Reply #4 on: February 11, 2026, 11:53:13 PM »
Joe,
That is really close, especially if it floats center line with the rotor.
Is the leverage ratio the same as the stock caliper too (calculate piston face area)?
« Reply #5 on: February 12, 2026, 07:32:11 AM »
Joe,
It's so close that HONDA should have made it the same size... ;)
The Caliper Pistons are the same diameter, so I would say the lever ratio is the same....it works really good and it's a very clean look.
:D
Offline All250R
« Reply #6 on: March 31, 2026, 08:12:28 PM »
Joe,
:D
I haven't done much with R tech, or riding since we focused on our relocation to ID.
That caliper is still used for 2026 bikes. Have you done anything to make this a kit for people to buy? If the leverage ratio is the same, seems like a great solution, given how many stock pistons and calipers are corrosion damaged by now.
I still need to get my cylinder head prototype dome machined and tested - however, my lathe got damaged in the move. At least I have lots of ground to actively test now.
