Author Topic: '88 swingarm question  (Read 2292 times)
Offline PNWrider
« on: February 15, 2015, 09:31:27 AM »
How do I remove this collar in the swingarm? And why have my swingarm never had bearings
« Reply #1 on: February 15, 2015, 12:55:43 PM »
I tried using pullers and punbches without success. Ended up building a tool. Basically a bolt, nut and washers at both ends. Washers will sit on the bearing and end of the swingarm.  In order to get washer to fit on the bearing side, I cut it into an oval shape. This allows it to slip in at an angle. Tightening the bolt and nut will pull the bearings out.
Once the bearing gets close to the edge it should be easy to tap out with a long punch. I typically use an extension, as they are rounded and won't damage the swingarm. If that won't work, use a socket or piece of pipe that has a slightly larger id than the swingarm pivot. Use it and the puller to pull the bearing all the way out.
Hope this helps
Best regards
-Jason
Offline PNWrider
« Reply #2 on: February 16, 2015, 01:30:23 AM »
Have a picture of that tool? Thanks
« Reply #3 on: February 17, 2015, 11:37:41 PM »
Unfortunately I am about 2500 miles away from it. Recently moved to Texas and all my stuff is in Washington
Best regards
-Jason
Offline PNWrider
« Reply #4 on: February 18, 2015, 01:35:50 PM »
Quote from: 2ndmoto;50367
Best regards
-Jason
Perfect! I live in WA I'll go pick it up lol.
I hate moving
