I got some more parts in.Durablue axle nuts,RTC radiator fins,,Duncan racing repack kit and chrome down turn end cap,NPM black throttle cover and 2 bolt silencer hanger.The regular single hole exhaust hangers and black brake resivour are currently out of stock.I should be picking up some parts from the vapor blaster tomorrow.I had him cleaning up front and rear durablue hubs,PT trx race pipe and silencer.When I got the PT pipe it had a raw finish with visible weld burns but had a light coat of surface rust and the silencer was quite dull.I mocked up the from a arms until I get the new. Bushings and bearings from JD performance,also mounted up the rear shock and linkage.Today I’ll clean up the swingarm and mount it up,I think I’ll order my bearing carrier as well so I can get the rest of the rear together.I still need to order flexx bars,tires,bunch of Oem hardware and few grommets.hand controls,anti vibe bar mounts,steering stem mount and a bunch of other random stuff.There are a few fourwerx bits I’d like to buy as well once they replenish their inventory.
I
