Author Topic: 87 R willing to take partial trades  (Read 2766 times)
Offline Bigred
« on: August 27, 2013, 10:04:53 PM »
I took this in on trade. I would keep it but my suv is in need if expensive repairs. I have taken this bike out and riden It. Only leaks are from the exhaust could use rtved.
265 ported oem cylinder feels like a mid port not sure who ported it
38mm carb was told its a airstriker ill look at to find out
red silicon hoses with inline temp gauge and cooler
clutch feels great no play or slipping
front tires are dunlops on oem wheels I have itp chrome ones gor it there a little beat up but will work
rear tires are turf tamers on itp rims
chain looks newer and In good shape
dominator 2 rear axle stock to +4 dual row carrier and aftermarket lock nut
oem rear plastics they do have a crack maier fronts still working on mounting them solid seat looks stock no rips
all bearings are tight look like they were replaced recently aarms and swingarm
frame has been welded on one of the bars on the sub frame will get a pic.  There was a crack welded up front on the upper rail by the sterring stem mount area also has tabs welded on look like the might have been used for mounting the maier plastics again will get the pics
Will do partial trades on a older aftermarket frame that stock parts will bolt to.         Plus1 a arms           bigbore motor    nice exhaust pipe
looking for 2500.   s part out is possable
« Last Edit: August 27, 2013, 10:59:13 PM by Bigred »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Bigred
« Reply #1 on: August 27, 2013, 10:07:45 PM »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #2 on: August 27, 2013, 10:09:24 PM »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #3 on: August 27, 2013, 10:27:41 PM »
Also has boyseen reeds and I have a stock 86 headlight for it and a case saver its not the best kind but better than nothing
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #4 on: August 28, 2013, 12:53:12 PM »
Will do partial on a trailer also
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #5 on: August 28, 2013, 11:24:57 PM »
Looks like a part out ill get it posted next week sometime mods can delete this if they'd like
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
« Reply #6 on: August 28, 2013, 11:41:12 PM »
My 87 with a Denton swingarm on it was missing the chain slider when I bought it like yours.  Depending on what kind of shape they are in and how much I'd be interested in the nerfbars with footpegs.  As long as you think they would polish up nice.  Good luck with partout...I never had the heart to part one out yet. lol
