Author Topic: Dress Up Products  (Read 27800 times)
Dress Up Products
« on: July 05, 2013, 10:10:18 AM »
All items can be purchased here: Dress Up
« Last Edit: July 05, 2013, 10:31:47 AM by Pumashine »
Dress Up Products
« Reply #1 on: July 05, 2013, 10:10:47 AM »
85/87 TRX250R/ATC250R Engine Dress Up Kit
This kit includes:
Polished OEM Ignition Cover
Polished OEM Clutch Cover
New Reusable Cometic Gaskets (Ignition/Clutch Cover's)
Polished Stainless Hex Mounting Bolts (6 for Ignition/16 for Clutch)
Polished OEM Waterpump Cover
New OEM Mechanical Seal, Waterpump Bearing, Seals, Separator Plate, Gaskets and Copper Washers.
New OEM Oil Fill Cap with New Oring
You will never have to buy gaskets again when refinishing the shine. Extra time was taken on each set to remove all polishing compound (inside/outside) for a great finish and ready for instant installation.
Dress Up Products
« Reply #2 on: July 05, 2013, 10:13:24 AM »
TRX250R Engine Mount Kits
Kits include: 2 OEM Style Engine Mounts
Made out of 304 Stainless Steel, Mirror Finish on Both Sides, .120" Thick
Fully Polished Bolt/Lock Nut Available for $10 Extra
Please Note - Design on Mount is just to show Reflection
Plain
Window
"X" Window
« Last Edit: July 05, 2013, 08:51:16 PM by Pumashine »
Dress Up Products
« Reply #3 on: July 05, 2013, 10:14:20 AM »
TRX250R Custom Coil Mounts
Used to mount a coil for a CR250 Upgraded Ignition System
Coil Not Included
Natural Finish
Polished Finish
Dress Up Products
« Reply #4 on: July 05, 2013, 10:14:54 AM »
1986 TRX250R Polished Radiator Shroud Mounts
Made out of 304 Stainless Steel, .048 Thick (Same as Stock)
Dress Up Products
« Reply #5 on: July 05, 2013, 10:15:30 AM »
TRX250R Stock Replacement Chain Slider Stay
Made out of 304 Stainless Steel, .036 Thick
Polished on Front Side
Also works with UPP Chain Sliders
Dress Up Products
« Reply #6 on: July 05, 2013, 10:17:55 AM »
Can you make it an option for ALL the parts to come in a raw un-polished finish. Some don't like things all shiney.  And when am I going to see a front sprocket guard on there.
Oh and thanks for the parts at a great price.
Dress Up Products
« Reply #7 on: July 05, 2013, 11:41:17 AM »
Quote from: Rupp250;692
The price of polished stainless verses regular is roughly the same. So in the beginning all parts were made of shiny material. It can be painted easily. But if you want the natural finish I would be happy to make them that way. Thanks Russel!
Offline Farmboy1979
Dress Up Products
« Reply #8 on: July 05, 2013, 12:02:14 PM »
Think you can make frame guards to protect the sides of the frame where your boots rub the paint off?  I'll even chip in for some of your R&D time if it would help.
Dress Up Products
« Reply #9 on: July 05, 2013, 01:09:29 PM »
I saw this once before. Do you have any links to show what you are referring to?
Offline Farmboy1979
Dress Up Products
« Reply #10 on: July 05, 2013, 01:32:30 PM »
[ATTACH=CONFIG]147[/ATTACH]
Something like this.
Offline Farmboy1979
Dress Up Products
« Reply #11 on: July 05, 2013, 01:33:36 PM »
Sorry... Thought you never saw my post and really am wanting these....,
Dress Up Products
« Reply #12 on: July 05, 2013, 01:48:44 PM »
What type of material do you think they should from?
Offline Farmboy1979
Dress Up Products
« Reply #13 on: July 05, 2013, 02:10:17 PM »
Well, I would prefer 316 stainless with a nice polish or better yet carbon fiber.  I'm not picky though.  What is easiest for you to work with?
Dress Up Products
« Reply #14 on: July 05, 2013, 02:58:37 PM »
Carbon fiber is nice. I cannot do anything in that area. You would have to contact the place that makes the one in the picture. Polished stainless would I would have to work with.
