Author Topic: Gusset Kits  (Read 22427 times)
Gusset Kits
« on: July 05, 2013, 10:16:11 AM »
All items can be purchased here: Gusset Kits
You can view how to install pictures here: https://www.forums.trx250r.org/index.php?action=dlattach;topic=4525.0;attach=2426
« Last Edit: November 08, 2019, 12:51:01 PM by Pumashine »
Gusset Kits
« Reply #1 on: August 29, 2014, 12:42:11 PM »
The replacement lower mounts are great. I would grind off the originals and install weld in the pumashine mounts regardless if the originals are still good. The new metal is thicker. Seeing that out frames are 20 something years old all of our lower motor mounts are ovaled to some degree.
My subframe was cracked and repaired by the previous owner. I also cracked the same repair. Cleaned up the area, welded in a pumashine subframe gusset and it has not given me a problem since. Same goes for the rear fender mount area.
Tony's gusset kits breath life back into out frames. The next best thing to a aftermarket frame is a well guesseted frame.
Offline Pricecheck
Gusset Kits
« Reply #2 on: November 03, 2014, 10:09:11 PM »
On top of all of this greatness offered, Tony shipped it out to Alaska and within a few days it arrived here! I can't wait to get her all welded up.
Offline jamieg45
Gusset Kits
« Reply #3 on: September 09, 2015, 08:06:37 AM »
tony do you make the pieces for the front motor mounts on a 87-89 frames. Need to replace both of them on each side. If needed I will post pics of what I need.
01 Lsr 250r
00 Walsh 250r
Offline jamieg45
Gusset Kits
« Reply #4 on: September 22, 2015, 08:24:39 PM »
Thanks tony, the boys are getting a few R's and the need some minor repairs.
01 Lsr 250r
00 Walsh 250r
Offline dirtygerman
Gusset Kits
« Reply #5 on: June 04, 2016, 06:26:56 AM »
Thank you for the high quality product!  I will post some pictures after I am done welding the guesset kit in place.  I was very pleased to see it wasn't just a laser or water table cut plate kit the bend on the shock tower reinforcement square tube was bent with knowledge of seam strength placement on a bend!
Offline dirtygerman
Gusset Kits
« Reply #6 on: October 31, 2016, 05:49:00 PM »
Thanks again for the great product!  I just ordered a front motor mount set from you Friday I should be getting my frame and other misc parts back from powder coating later this week.  I am so excited!
