Author Topic: Pumashine thanks for the Gusset kit looks great and have a question  (Read 20784 times)
« Reply #15 on: September 12, 2013, 11:19:59 AM »
Quote from: Outlaw525;11557
But if 3/8 has held up for 20 some years it will work for another 20
Update on this project. I went on ebay and bought Honda TRX 450R Foot Pegs & Heal Guards---04-05 for $60 shipped. So the plan is to make a foot peg adapter for the 04/05. Another bracket that goes on the frame and secures the heel bucket. Once this is complete it will only take a small modification or none at all to use for the 06-13.
« Reply #16 on: September 22, 2013, 05:10:52 PM »
OK..........These are not as hefty as the ones Douglas made but I think they may look a tad better. I measured the height and were at 1/4" below OEM. As for front to back it matches the 450r. I will cut a pair of 3/8" thick tomorrow so you guys can see the end product. I ran out of battery on my camera. Sorry
« Last Edit: September 22, 2013, 10:32:03 PM by Pumashine »
« Reply #17 on: September 23, 2013, 10:46:59 AM »
Looks great Tony! I'm in for a set.. getting tired of the narrow RIS pegs so this makes moving to Roll pegs very attractive.
Offline Outlaw525
« Reply #18 on: September 23, 2013, 11:17:53 AM »
Looking good
1987 trx 250r esr310 kit
2007 525 outlaw irs
« Reply #19 on: September 23, 2013, 07:40:26 PM »
Quote from: Outlaw525;12861
Looking good
 Got my camera charged.   I am thinking we need to tap the front hole for a 10 MM bolt and order some OEM ones for the kits. 3/8" steel will give plenty of holding power for the 10mm bolt.
I checked about lowering pegs by 1/2" by swapping sides....actually raises them 1/2".. so that won't be happening unless both holes are moved down 1/2". Would have thread both those holes.
Offline Outlaw525
« Reply #20 on: September 23, 2013, 08:28:18 PM »
This is going to be great. Will love having wide pegs that don't move around and feal like they will fall off when I get on. And give every one a option for aftermarket pegs. I thank I bling star makes a set of pegs for a 450 that are -1 in. Will have to look into them if I need them to be lowered.for now stock 450r pegs will work. Or at least tell winter when she gets torn apart for restoration.
2007 525 outlaw irs
« Reply #21 on: September 26, 2013, 04:07:45 PM »
I ordered bolts so you guys can install these in a few minutes. Plan on just painting them black. These are the final parts made from 3/8" steel.
Offline Outlaw525
« Reply #22 on: October 01, 2013, 09:56:33 PM »
When you going to have everything ready to ship and how much for my set. That way I can get you payed. Thanks
2007 525 outlaw irs
« Reply #23 on: October 01, 2013, 10:27:55 PM »
I ordered the bolts. I am still tapping the 10mm fine thread holes. Going to send all the parts off to get black anodized. So we are still a couple weeks out.
Offline Outlaw525
« Reply #24 on: October 15, 2013, 09:35:28 PM »
How's it coming on the mounts.
2007 525 outlaw irs
« Reply #25 on: October 23, 2013, 09:46:10 AM »
I finally got the parts, bolts and washers bead blasted and clean out to black zinc. Should be 4 - 5 days.
Offline bnau267
« Reply #26 on: November 17, 2013, 07:50:22 PM »
How'd they turn out.
« Reply #27 on: November 18, 2013, 04:26:21 PM »
Quote from: bnau267;17715
The black zinc turned out great.
Cost for the set of 3/8" thick adapters and bolts for foot peg adapters is $24. The stock flange bolt will need to be reused for the rear hole mount. $6 to ship puts the total cost at $30 for the set shipped.
Offline JR250R
« Reply #28 on: November 18, 2013, 07:50:33 PM »
How many set did you make to sell? Or are they accounted for?
« Reply #29 on: November 18, 2013, 08:34:44 PM »
Quote from: JR250R;17777
I took a gamble and built 30 sets. There is a minimum of $80 on black zinc plate. The bolts come black iron but would rust once they got wet. The bolts were bead blasted clean and baked after plating to put the strength back in them. I will be putting them on the website this week.
