Author Topic: Oem big bore cylinder 72mm with cut oem head  (Read 5725 times)
Offline Outlaw525
« on: September 08, 2013, 10:29:01 PM »
Oem big bore cylinder 72mm with cut oem head. Cylinder is ported for mid to top end has a really nice port work. Unknown porter has a number on bottom of cylinder from porter. Number is 15269. Bore is at 72mm firs bore on the cylinder. Cylinder is in ok shape I have done a light hone with a stone hone and cleaned up good needs a final hone with ball hone. Could be used with just a piston and hone but will leave it up to the buyer. $150 obo update
« Last Edit: October 18, 2013, 09:10:58 PM by Outlaw525 »
1987 trx 250r esr310 kit
2007 525 outlaw irs
Offline Outlaw525
Cylinder pic
« Reply #1 on: September 08, 2013, 10:38:50 PM »
Pic
2007 525 outlaw irs
Offline genoapb
« Reply #2 on: September 09, 2013, 06:44:51 AM »
does it have any trouble holding a head gasket and are the ports raised at all? looking to build a stroker sleeper setup.
Offline Outlaw525
« Reply #3 on: September 09, 2013, 11:20:30 AM »
Didn't have trouble with head gasket ran cool. This engine had be to tether for a long time. Don't know how long but it had a 87 style big bore piston and they haven't Been made for a long time. Piston was for a long rod crank and didn't use a spacer plate. Water pump shaft broke due to the balancer bearing going out or it would still be runing. As far as the port timing goes I don't know. I could measure it if you have something to go off of.
2007 525 outlaw irs
Offline genoapb
« Reply #4 on: September 09, 2013, 05:21:46 PM »
if you could just measure from the top of the cylinder down to the top of the exhaust with a pair of calipers and get the same measurement to the top of the transfers. that would be great.
Offline Outlaw525
« Reply #5 on: September 09, 2013, 08:24:32 PM »
Top of cylinder to exhaust is 42.5 mm
top of cylinder to transfer ports is 60.5
ports are very even they are as close to the same hight as you could get
Bore with my caliper measure 72.01
well let the buyer make the call on the bore could be used but is always better to bore
2007 525 outlaw irs
Offline Outlaw525
« Reply #6 on: September 19, 2013, 08:03:44 PM »
Ttt
2007 525 outlaw irs
Offline mx333
« Reply #7 on: September 19, 2013, 09:53:13 PM »
$125?
Offline Outlaw525
« Reply #8 on: October 18, 2013, 09:09:24 PM »
Ttt 150 shipped need this to find a new home
2007 525 outlaw irs
Offline Bigred
« Reply #9 on: October 18, 2013, 09:31:40 PM »
If I had the cash I'd love this
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline jfwyatt1
« Reply #10 on: October 18, 2013, 10:36:07 PM »
wish you i had seen this a week ago dont know how i missed it good luck with sale
Offline Bigred
« Reply #11 on: October 18, 2013, 10:46:37 PM »
If this guys pics some parts up this Sunday ill buy it  this is what I wanted to build
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
