Author Topic: Pumashine's New Hotness - Rezzy clamps  (Read 5529 times)
« on: September 09, 2013, 09:21:12 AM »
Here are some pics of the reservoir clamps that pumashine made for me to fit my Custom Axis rezzies. They look alot better than the metal band clamps. Tony, you should add these to the for sale list!
Before Pic with metal band clamps:
[ATTACH=CONFIG]1792[/ATTACH]
After with new rezzy clamps:
[ATTACH=CONFIG]1793[/ATTACH][ATTACH=CONFIG]1794[/ATTACH][ATTACH=CONFIG]1795[/ATTACH][ATTACH=CONFIG]1796[/ATTACH]
« Reply #1 on: September 09, 2013, 09:26:26 AM »
Looks good!!
Offline JoePA
« Reply #2 on: September 09, 2013, 09:28:59 AM »
Those look Awesome and work as good as they look!!!
« Reply #3 on: September 09, 2013, 09:34:54 AM »
I was very happy with the fitment. I was worried about where the location of the adjustment knobs on the compression rezzies would end up, but I was able to twist them just a little bit to point out toward the sides, which was great! The knobs are easy to get to, the hoses are clearanced well away from the frame, the rezzies are still protected from impact, and opens up the cooling area a little bit for the radiator.
« Reply #4 on: September 09, 2013, 09:35:54 AM »
I always hated the look of a hose clamp on the rezzy's...
Awesome job Tony!
« Reply #5 on: September 09, 2013, 09:53:58 AM »
The frame upright is not square where these mount so they only go on one way. Had to make clearance for the little posts that are welded to the frame for the OEM nose cone. So the template is done. The C portion of the clamp is modified to fit your reservoirs. In time I'm sure we will get all the sizes figured out. Just need to know the diameter of your ressies. Preferably measured with a dial caliper.
Offline Quinnlt4
« Reply #6 on: September 09, 2013, 11:07:27 AM »
Can you make some for the rear rezzy? I am probably going to remove the mounting brackets this winter in hopes of getting a clamp like this.
1986 Laeger wannabe
« Reply #7 on: September 09, 2013, 11:25:22 AM »
Quote from: Quinnlt4;11621
I think a rear one would be pretty cool, especially for the aftermarket shocks so you could put the rezzi right above the pipe mounted on the upper frame tube just below the gas tank. My TCS rear shock was setup like that, but I had to use a metal band clamp instead.
« Reply #8 on: September 09, 2013, 11:43:02 AM »
For the Pep guys,I will have some piggy back clamps this week if Puma wanted to copy them. They aren't the actual Pep ones,just ones that somebody machined,but they will allow the rezzy to be mounted to the shock. I would still recommend the shorty hoses but Im sure they could be tucked/routed out of the way.
Offline jamieg45
« Reply #9 on: September 09, 2013, 12:47:34 PM »
Awesome guys and great offer Eric on the clamps.
01 Lsr 250r
00 Walsh 250r
« Reply #10 on: September 09, 2013, 01:08:03 PM »
Stock rear resi/old peps 2.225".
« Reply #11 on: September 09, 2013, 01:28:44 PM »
And if puma wants to do some for round frames I can send him mine this fall/winter...
