Author Topic: more compression  (Read 3181 times)
Offline 2k1lvr
more compression
« on: September 12, 2013, 12:24:34 PM »
I have an 88 motor stock stroke and on the second bore,stock porting. I would like to raise comp to around 210 or more what size dome would I need in a pro design cool head to get to that? And let me know if that's with stock 3 piece gasket. I know I need to do a uccr or what ever its called to be sure but I want to know about what I need. I might buy the head from a buddy but not sure what all size domes he has. And i know i will need race gas Thanks!
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
more compression
« Reply #1 on: September 12, 2013, 02:53:57 PM »
You can run a Cometic 0.010 steel head gasket or on the 3 piece trx gasket peal it apart and run just 1 of the thin gaskets  and save the other
Offline 2k1lvr
more compression
« Reply #2 on: September 12, 2013, 05:56:41 PM »
I'm running one thin pieces of a stock gasket now but my friend has the cool head for sale cheap to me and he has several domes so i was just wondering which dome would get me where i want to be.
more compression
« Reply #3 on: September 12, 2013, 10:04:11 PM »
On my oem cyl 265, Cool Head with 18 or 19cc dome and .010 gasket I pulled 230psi.
Offline 2k1lvr
more compression
« Reply #4 on: September 13, 2013, 04:06:06 PM »
thanks!!
