Author Topic: 1986 trx250r with 88 motor fresh build  (Read 5047 times)
Offline ayomainstreet101
« on: September 18, 2013, 09:18:22 PM »
This was my winter/summer project. I have over 5000 in it with receipts, but I need some cash due to moving to Texas for school. It is a 1986 frame that has been powder coated. Ill start with the rolling chassis. It has new fullflight +3+1 a arms with lifetime warranty, hiems joints, tirods, powder coated oem stem, tag alius bars with risers, new +3 braided brake lines, rpm tapered bearing carrier with tapered bearings, all balls stem bearings, sunstar 13:38 sprockets, with renthal oring chain, chain sliders, swing arm rebuild kit by pivoltal works, complete stainless bolt kit, itp holeshots on new itp wheels, ambush rear on used itp t9 beedlocks. It has used hubs and spindels with new bearings, calipers, 450r front shocks, oem rear shock, oem powder coated rear swinger with blue paint over it, oem axle and hubs. The motor is an 88 that I bought used an rebuilt. It has ck 109 hot rods crank with bearings, wisco 68mm piston and rings with .006 ring gap, fresh bore, performance engineering basket, hinson clutches, ricks 200 watt stator, pro design head, have the low compression head gasket on it but also have one to bring it up too 210, fmf fatty full pipe, pro design case saver, 34mm carb, stock air box with lid and tubes, uni air filter, clots gear oil and air filter oil, motion pro twist throttle, scotts half waffle grips, oem radiator powder coated, rick stock curve cdi "2" new, race cut harness, ac nerf powder coated one is missing net, gripper blue and black seats, oem plastics shave and painted. im sure im missing a lot but just ask with any questions. Ton of spare parts to go with, cases, cylinders, cdis, stator, axle, hubs, etc. Im located in boydcounty ky, like to get 3000obo. It ant letting me post pictures so ill have them posted later.
Starting to love my 250r more and more!!
« Reply #1 on: September 19, 2013, 02:45:39 AM »
Text 6063719413 and i can send pics it's a clean quad.[attach=config]21393[/attach][attach=config]21394[/attach][attach=config]21395[/attach]
« Reply #2 on: September 19, 2013, 02:46:26 AM »
« Reply #3 on: September 19, 2013, 03:03:14 AM »
« Reply #4 on: September 19, 2013, 03:06:51 AM »
