Author Topic: KTM temperature and elevation corection chart  (Read 5048 times)
« on: September 19, 2013, 11:07:38 PM »
Offline atvmxr
« Reply #1 on: September 20, 2013, 10:07:13 AM »
interesting!   doesnt humidity come into play as well?  (maybe figured into elevation, as in general, the higher elevation the humdity goes down - usually)
so 165 main and 45 pilot at sea level and 90 degrees. (.98) on graph.  If I were to go to waynoka at ~2000ft (.95), then (.95/.98) * 165 = 159.95 = 160 main?
is that right?
« Reply #2 on: September 20, 2013, 11:46:39 AM »
I would say yes you are correct, another way to do the math would be .98 -.95 + .03 x 165 =   4.95 - 165 = 160 main
I am sure humidity should be factored in also along with atmospheric pressure also but the calculator would be much more complicated
« Last Edit: September 20, 2013, 04:47:29 PM by rsss396 »
