Author Topic: Trikers! Post up pics of your 3-wheeled death machines!  (Read 168870 times)
« Reply #105 on: August 17, 2013, 01:27:29 PM »
The new transformations are just beautiful. The old frames with new suspension and motor technology make me wish it was 1985 with 2013 technology.
Offline Black Sheep
« Reply #106 on: August 18, 2013, 05:55:54 PM »
Quote from: Pumashine;8932
Not sure if you are refering to the TPC or something else, but TPC's are all new, frame included. No old school parts involved
Offline RIDE-RED 350r
« Reply #107 on: August 18, 2013, 08:16:09 PM »
Quote from: Black Sheep;9097
That 450x and the Patriot trike are my favorites! Nice work you do Bill... :)
« Reply #108 on: August 18, 2013, 09:29:21 PM »
Sorry, what frames are you using?
Offline Black Sheep
« Reply #109 on: August 19, 2013, 04:33:28 AM »
Quote from: Pumashine;9118
My own design.
Offline KASEY
« Reply #110 on: August 19, 2013, 09:28:51 AM »
its not rocket science and if you search around you will find that they take a swazall to the trz frame and cut it in half,, then add to whats left to built the front half .   there has always been talk of a complete cromoly frame but as I have not seen anything yet to show there has been one built . big news like that usually is all over when it happens.
Offline mrtwidster1
« Reply #111 on: August 19, 2013, 11:17:04 AM »
Not to side track but if I repair my trike frame like welding and gussetting, should I get it magna fluxed to inspect it for stress? Sorry for the off the wall ?
Offline Black Sheep
« Reply #112 on: August 19, 2013, 05:51:31 PM »
Quote from: kasey;9158
LOL, How many are out there now  :confused-new:   I didn't realize you have been to my shop and seen how we do it.  :disillusionment:  I guess that's why you're using a bike frame :p
Offline Black Sheep
« Reply #113 on: August 19, 2013, 05:57:26 PM »
Quote from: mrtwidster1;9167
It's not a bad idea. If you can, on a 27 year old frame, I sure would.
Offline KASEY
« Reply #114 on: August 19, 2013, 08:13:12 PM »
like I said its not rocket science,,  over the years you have posted several picts of you and others cutting up trx450r's with a sawzall,,  its also common knowledge you use the rear half of the trx450r frame with the suspension and subframe points all intact ,,,  there are a lot of very smart people here who pretty well know what it takes to build a project like this,  and most probably already know its your design added to a section of frame which is a production Honda part, as for the complete cromoly frame built by you,,,,,,  like I said if it was a reality.. it would be common knowledge too,,,
Offline mrtwidster1
« Reply #115 on: August 19, 2013, 09:06:54 PM »
Quote from: Black Sheep;9212
Thanks for the reply. I have access to a portable magnaflux is why I asked. My next build will see a modified frame.
Offline Black Sheep
« Reply #116 on: August 20, 2013, 05:01:07 PM »
Quote from: kasey;9224
What's the matter, things slowed down at 3W.O since I am no longer there so your trying to pick a fight here :sign0108: Your common knowledge is based on internet forum information. Why do you care how I build them?
Puma thought I used old 85/86 frames so I corrected him.
Do I use part of the TRX frame on most builds, yea sure do. No point in rebuilding the same thing. A little FYI for you. Most frame builders outsource parts to. http://www.jjandaracing.com/contents/en-us/d15.html Shock mounts, engine tabs, steering tubes, Swingram builders out source the piviot area and axle carrier. Nick Nicholson built custom ATC frames and Honda supplied all the gussets, neck, and all stamped parts. All he did was bend and weld the round tube. So, what's your point.
Chromoly frame. You have no idea whats in my shop. I have one sitting on the floor right now. Someday I want to replace my original "half-breed" frame. Problem is, all the original frame does is keep winning ;) 6 years ruuning and no problems yet. It's kinda a testiment and how good they are :P  Truth is though Chromoly is not really the best material for a ATV frame. It's is heavier, and to hard. Whereas DOM will flex and not crack like Chromoly does. But, I leave that option up to the buyer. They get what they ask for. I have had only two people order chromoly and those builds are being done at the owners place/time. I have no control over when they finish their trikes. When I get pics, sometimes I post them.  You really want to see a chromoly frame...buy one :)
Of course I could have taken the easy way out and used a bike frame...but those things never handle well. I stick to my race proven ways though :biggrin-new:
p.s. the sawsall...that was all for shock value, nothing like seeing a brand new quad chopped in half :cower:
Offline KASEY
« Reply #117 on: August 20, 2013, 08:23:40 PM »
nobody is trying to pick a fight here,,  and look a detailed answer for a few that like to know things,,  thanks for a real answer with a little detail,,
Offline Black Sheep
« Reply #118 on: August 20, 2013, 08:29:58 PM »
Well the thread is about showing trikes, not getting into detail about TPC's. I wasn't trying to avoid anything, just respecting the original intent.
Now let see more trike pics.
Offline KASEY
« Reply #119 on: August 20, 2013, 11:30:08 PM »
new project,, pro-link type suspension on an ATC70
