Author Topic: gasket remover on powder coat?  (Read 3729 times)
Offline Victork
« on: October 06, 2013, 11:04:55 PM »
Has anyone used gasket remover to take powder coat off?
Offline jamieg45
« Reply #1 on: October 07, 2013, 11:21:00 AM »
I haven't tried that before but I use aircraft stripper. You can buy it in a spray can or a full gallon and brush it on, and it will take powder coating off. Let it sit on for a bit scrub with a wire brush and power wash it off, that is what I have done and it has worked.
01 Lsr 250r
00 Walsh 250r
Offline Victork
« Reply #2 on: October 07, 2013, 12:43:36 PM »
Where can i buy it jamie?
Offline Fire1
« Reply #3 on: October 07, 2013, 01:54:13 PM »
Depending on what part you want to remove it from you can take a torch and move it back and forth and the powder will begin to flake and when you hit it with bead blaster it comes off like nothing.
Offline Victork
« Reply #4 on: October 07, 2013, 02:18:30 PM »
A arms and tie rods. The guy doing the powder said his sandblaster isnt removing it
Offline Victork
« Reply #5 on: October 07, 2013, 02:39:30 PM »
I thought about buying new arms and selling mine but im gonna finish mine. Mine are +2 +1 lsr race arms. 75 for mirror black powder, 316 for ALL new hardware...
Offline Fire1
« Reply #6 on: October 07, 2013, 02:52:11 PM »
Give the torch method a try. When the powder get hot enough it converts back to powder and the sand blaster should knock it right off.
