Author Topic: Aluminum Axle info  (Read 5957 times)
Aluminum Axle info
« on: October 16, 2013, 03:48:58 PM »
So what is out there? Thinking of a solid play axle. Anyone with experience on a duner?
Modquad
LSR
JJ&A
Aluminum Axle info
« Reply #1 on: October 16, 2013, 06:36:16 PM »
JJ&A is my go to choice. Jeff puts out a really piece and stands behind his work.  ModQuad was/is a copy and the early ones I saw lacked quality.  LSR looked nice but were expensive.  I ran a 34" solid play axle for a while and liked it a lot - just wish it was longer/wider.
Offline Vader
Aluminum Axle info
« Reply #2 on: October 16, 2013, 07:26:46 PM »
I run solid 34" aluminum play axles on all my duners... ATC, TRX, LTR.  My Hondas  have Modquad axles and the Suzuki is a JJ&A.  The Modquad axles are about 1 lb lighter than a comparable JJ&A.  I also had a Fireball aluminum axle on a different ATV I used to have.  All 3 brands are of very good quality but the JJ&A would get my vote for the best overall quality because the hubs are little more stout and the Allen bolts are stronger grade fasteners.  I've never had an issue with any of them jumping or duning.  The aluminum dulls pretty quickly in the sand but can easily be brought back to a polished look if you keep up with them after each trip.
85 Missile 310R Duner
86 ATC 330R Duner
88 TRX 350R Duner
06 LTR 535 Duner
Offline Polonda
Aluminum Axle info
« Reply #3 on: October 16, 2013, 09:04:12 PM »
JJ&A gets my vote.  Great to deal with.  They replaced a hub for me no questions asked.
Offline taft372
Aluminum Axle info
« Reply #4 on: October 17, 2013, 12:01:05 AM »
I have a fireball 34in on my 250r that o drilled out to get rid of more weight. And modquad on my yfz 34in that I drilled out as well. Jj and a is a great product. And I would gladly get one, I just got these others at a better price.
Offline taft372
Aluminum Axle info
« Reply #5 on: October 17, 2013, 12:12:16 AM »
Lonestars alum axle is splined and comes loose often no matter how much you tighten, jj and a, modquad, and fireball are all key wayed and the pinch bolts work great!!!
Aluminum Axle info
« Reply #6 on: October 17, 2013, 04:13:01 PM »
Is Fireball the only one that is available in 40". Thought I read that somewhere.
Offline taft372
Aluminum Axle info
« Reply #7 on: October 17, 2013, 05:46:07 PM »
As far as I know 34" is the longest you can get
