Author Topic: Esr 330r jetting  (Read 3995 times)
Offline fast350r
Esr 330r jetting
« on: October 19, 2013, 06:13:19 PM »
Hi guys i need help jetting my esr330r , its a 77mm bore with trx9 porting , trx11 standard mount pipe, 38mm a/s . Esr air box eliminator , race gas dome running sonoco 110 , stock ignition +4 advance ,
currently im running 52p , 1 1/2 turn AF, 182m and dgh needle in the middle . And its rich at idle , runs good after that, im 1100 altitude and 85 degrees outside .
I just need some advice in jetting , Thanks in advance
Shearer 431 puma
Offline Bowtie316
Esr 330r jetting
« Reply #1 on: October 19, 2013, 11:01:06 PM »
I have a similar setup (344 and 38a/s) and the last time out I used 52p, 188m and DGH in the second clip, that worked pretty good but I want to try a needle that is a touch leaner in the middle.
Offline fast350r
Esr 330r jetting
« Reply #2 on: October 20, 2013, 12:33:28 AM »
Ok thanks bro il bump my main and see what happens
Shearer 431 puma
Offline Bowtie316
Esr 330r jetting
« Reply #3 on: October 20, 2013, 09:11:34 AM »
I usually bump up the main until it won't quite clean out then go back down one. The needle takes quite a bit of trial and error to get it right.  And I think a 50 pilot might be better for me but I want to keep it all a little rich until I get this thing broken in a little more.
