Workshop
Suspension and Chassis
YFZ450 front brake setup
Topic: YFZ450 front brake setup (Read 4127 times)
Vroomy
November 02, 2013, 11:29:36 PM »
hi i know a few of you on here have done the YFZ front brake upgrade, im in the process of it on my bike but i have a set of stainless brake lines to suit my +3 arms and they dont really want to fit right? i think the angles on the ends are wrong cos i have to twist them too far and they get a bad kink. Is there a better line to use? maybe the YFZ ones?
05450r
November 02, 2013, 11:49:04 PM »
I used yfz dual lines on my first setup,worked great. Using the 400ex single to dual now with no issues also,but I did have to loosen the lines at the "Y" to get the kink out then retightened. I can take a pic of the line mounted to the caliper tomorrow to see the angle if you need
Vroomy
November 04, 2013, 07:49:24 AM »
i got dual lines but they definitely dont want to play the game. Might buy some yfz ones, what length would i need? i have +3 arms and a +2 stem
05450r
November 05, 2013, 01:01:46 AM »
Vroomy I think +3 would be just fine,I think mine were +2 yfz lines with +3 arms and +1 stem. Measure the length of your lines, I THINK yfz +2's are 54",if I remember right,and would probly work depending on the height of the bars.
bnau267
Total likes: 10
November 05, 2013, 01:58:33 AM »
Same here. Just installed +2 yfz streamlines (3 piece) on mine and they have plenty if not too much length for the arms. I have a standard length stem and +3 arms. If I were to do it again, which I probably will, I may go with the two line setup.
Vroomy
November 05, 2013, 08:34:30 AM »
thanks guys, ill get some ordered
Workshop
