Author Topic: Front Sprocket Guards  (Read 20928 times)
« on: July 06, 2013, 05:11:29 PM »
jcsoo3 wanted to see some sprocket guards developed. This one for the front is to be used if you do not have an OEM sprocket cover. This is a 3 1/2" stainless steel cover made of .o6o" thickness. There is a 2" diameter aluminum spacer behind it to keep the chain from hitting the guard. This was just a quick Prototype. Was not sure if adding in speed holes was going to be all right. Will ad some speed holes a little later. This is just an idea. Wanted to know what anyone thinks should be done.
Offline Turftamer
« Reply #1 on: July 06, 2013, 06:01:01 PM »
So that would spin with the sprocket?  Seems like you'd still have to worry about catching a pant leg in between that and the chain.  What about integrating one with your case saver?
« Reply #2 on: July 06, 2013, 06:30:48 PM »
Quote from: Turftamer;1238
Yes, it would spin. But better than having nothing at all. Making a complete guard like OEM is alot of work = alot of money.
Offline mrtwidster1
« Reply #3 on: July 07, 2013, 10:50:28 AM »
Pretty!!
(Note... Dont you hate it when your new engine finish gets chipped???)
« Reply #4 on: July 07, 2013, 10:54:10 AM »
That's because he didn't powdercoat those the proper OEM Honda way. Rookie
And yeah, speed holes for the win.  Make it look like a 6shooter cylinder.
Offline atvmxr
« Reply #5 on: July 07, 2013, 11:29:06 AM »
Not for me, these seems even more dangerous than the exposed chain sprocket
« Reply #6 on: July 07, 2013, 11:40:01 AM »
Quote from: atvmxr;1421
 Could be, that's why Rupp250 is getting a free set for product development. With speed holes I might add.
« Reply #7 on: July 07, 2013, 11:46:07 AM »
have you got to work on a rear sprocket and rotor guard?
« Reply #8 on: July 07, 2013, 12:00:43 PM »
Quote from: jcs003;1428
Are those supposed to bolt to the sprocket hub. You replace the sprocket hub bolts with longer ones?
« Reply #9 on: July 07, 2013, 12:13:59 PM »
Quote from: Pumashine;1433
i believe so.  i never seen one other than in pics.
« Reply #10 on: July 07, 2013, 12:27:47 PM »
Quote from: jcs003;1438
Do you put them on one side or both?
« Last Edit: July 08, 2013, 04:33:28 PM by Pumashine »
Offline Fire1
« Reply #11 on: July 07, 2013, 01:29:10 PM »
Here's a picture of mine. It's on both sides but they do make them for just one side.
« Reply #12 on: July 07, 2013, 01:34:58 PM »
Quote from: Fire1;1456
What kind of bolt is used? Do you have a pic of the other side?
Offline Fire1
« Reply #13 on: July 07, 2013, 01:38:31 PM »
I'm at work till tomorrow morning but ill take some detail pics tomorrow. It's a Allen head bolt that's recessed into the pâté on the back.
« Reply #14 on: July 07, 2013, 01:45:55 PM »
Great, thats makes sense!
