Author Topic: Ktm/trx250r 431 led puma build  (Read 16079 times)
Offline ktm250r
« on: November 08, 2013, 02:39:20 AM »
Well after my ktm/cr500 build turned out to be a big mistake I sold the engine and started a ktm/trx250r build, after fitting the engine swingarm mount and bottom mounts I had my local mod shop fab the front engine mounts and a fatty pipe made to fit the chassis, after putting 10 hours on it and not being able to take the smile off my face when riding it I decided its time for some more horsepower :) I contacted arlan at led preformance about building a 431 puma engine and custom exhaust and intake and he was excited to take on the build :) I found a good engine that has only been opened up once and a low hour 525xc rolling chassis to start this build fresh, arlan should be starting to work on the engine this month and then I have to ship him the chassis.
Plans for build
Engine:
-431cc CPI puma big bore kit
-led custom porting
-welded and balanced crank with ktm rod
-sling shot clutch
-cyroed and back cut tranny
-Ricky stator ignition to run lights/fan
-led exhaust and intake
-40mm billit smart carb
Chassis:
-plus 4 swing arm
-shocks ?
-all black plastics
-custom rad decals
-carbon fiber steering stem/bars/tie rods
-sx a-arms/seat/fuel tank
-presision steering damper/antivibe bar clamp
Here's some pics of the swingarm mount and front mount, I'm gonna let arlan do the bottom mounts, more pics to come
« Reply #1 on: November 08, 2013, 03:35:25 AM »
Neto! I like !
« Reply #2 on: November 08, 2013, 06:44:08 AM »
sounds cool!  tell us more about the carbon fiber stem, bars and tie rods.
« Reply #3 on: November 08, 2013, 08:43:25 AM »
Holy crap this is going to be sweet. I've seen a few two-stroke KTM motors being put in their quad frames but never a 250R motor.
Don't you be giving Arlan too much work...he is supposed to be working on my Sphynx lol
« Reply #4 on: November 08, 2013, 08:58:36 AM »
The 431cc with the +4 swinger will still be a hand full to ride. Pretty much a dream bike for anyone. Keep us posted!!!
Offline ktm250r
« Reply #5 on: November 08, 2013, 09:50:52 AM »
Quote from: jcs003;16930
I don't know much about the stem but here the site I found it, gonna see if he can make front engine mounts too
http://www.xstreamcomposites.com/www.xstreamcomposites.com/Home.html
Offline ktm250r
« Reply #6 on: November 08, 2013, 09:53:03 AM »
Quote from: Pumashine;16940
What size swinger do you guys run on duner pumas?
« Reply #7 on: November 08, 2013, 10:15:03 AM »
Very cool, always like the look of the Ktm's, and a Led Puma should make it that much better!!
Offline troybilt
« Reply #8 on: November 08, 2013, 10:15:38 AM »
Is this a duner bike or play/mx bike?  Sick build...  I was running a stock length swinger with my Saber, but its not the typical build.  I was going for an MX bike with a detuned Saber.
Elsinore 496cc Saber
« Reply #9 on: November 08, 2013, 10:44:26 AM »
Quote from: ktm250r;16945
they definitely have some cool stuff.
« Reply #10 on: November 08, 2013, 10:58:59 AM »
Quote from: ktm250r;16946
A +4 on a puma duner feels just right. No matter what the length you will still pull wheelies in all gears. I'm runnin stock, +2 and +4 on the 400's
Offline ktm250r
« Reply #11 on: November 08, 2013, 05:48:01 PM »
Quote from: troybilt;16950
Thanks :) I'm gonna try to keep it for just dunes
Offline christph
« Reply #12 on: November 08, 2013, 08:07:37 PM »
I'm thinking the pipe is going to be the biggest challenge, i.e., routing it through a frame built for a 4 stroke.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Offline ktm250r
« Reply #13 on: November 08, 2013, 10:07:24 PM »
Quote from: christph;17020
I've had it done twice already in ktm chassis, the biggest challenge with the exhaust is coming off the cylinder their is limited space, through the frame there's lots of room
Offline ktm250r
« Reply #14 on: September 18, 2014, 02:36:05 PM »
Some how someone else's pics ended up in my first post ^^^^^^^^^^^^ :s
I got some updates and pics from arlan at led, the frame is gonna have to be modified to fit the smart carb
