Author Topic: Trx250r Resi clamps  (Read 65467 times)
Trx250r Resi clamps
« Reply #45 on: November 10, 2015, 01:25:59 PM »
:rofl::rofl:
Quote from: Pumashine;60898
Am I supposed to remember what size those were? :rofl: I build hundreds of parts every day with thousands of different dimensions each job. The stock resi's are around 2.250"
Where's your cheat sheet :rofl:
Offline trx250scar
Trx250r Resi clamps
« Reply #46 on: November 10, 2015, 04:28:31 PM »
Well I didn't expect that you would remember my clamps but I did expect you would remember the OEM ressi size as the first time you made them you knew the OEM size. I figured it would be the same this time. My ressi is 2.245". Thanks
Offline slowstang89
Trx250r Resi clamps
« Reply #47 on: March 28, 2016, 02:32:45 PM »
Are you still making the resi clamps for a stock frame?
Trx250r Resi clamps
« Reply #48 on: March 28, 2016, 02:43:01 PM »
Quote from: slowstang89;66037
I will be making one last run so I can build a set for [MENTION=6]atv fan 28[/MENTION]
Offline slowstang89
Trx250r Resi clamps
« Reply #49 on: March 28, 2016, 02:46:09 PM »
I will take 6 if you can do that...you just need my resi size?
Sent from my E6782 using Tapatalk
Trx250r Resi clamps
« Reply #50 on: March 28, 2016, 05:08:25 PM »
Quote from: slowstang89;66042
Yes sir. Use a dial caliper if available
Re: Trx250r Resi clamps
« Reply #51 on: September 03, 2017, 03:50:56 PM »
So this guy wants clamps made and never gives me the cut size. I am so tired of the important people (in their minds) and the equally stupid peeps on face book I cannot make these anymore. Now if your are a real member here just send me the resi diameters and we will get stuff done! For example
The message they sent you was:
I'm needing two clamps both for a stock frame. I'll get sizes for you sometime today. But wanted to be sure you would want to make them.
Thanks,
Gene
« Reply #52 on: August 18, 2018, 10:06:21 AM »
If there are any members here would like resi clamps, let me know so we can get an order going.
Offline Sand_Blaster
« Reply #53 on: August 04, 2019, 02:46:42 PM »
Tony you still up for making clamps? I need 2 for some works, and my buddy needs 2 as well for his works. I can get you specs in a bit if you are interested.
87 Trx250r & 99 Banshee
