Author Topic: 36 a/s jetting baseline?  (Read 3139 times)
Offline atvmxr
« on: December 01, 2013, 11:30:32 AM »
No luck searching or reading through posts. Need base jetting suggestions for 36 air Stryker - needle, pilot, main jet etc
88 trx Stock motor Fmf pipe, silencer Belray oil 50:1 Air box lid off Boyeson reeds
Near sea level.
Thanks!!
Offline atvmxr
« Reply #1 on: December 03, 2013, 05:50:42 PM »
just in case anyone tries to search for this in the future, on the other site Carlos recommended:
"165 to 172 Main
48 to 52 Pilot, sometimes even 55
DGH Needle on 3rd clip, or 2nd
1 1/2 on the AS
This will put you a hair Rich In SoCal at Sea Level.."
so thats what I will start with (eventually when done with the build)
Offline RyanWsly
« Reply #2 on: December 04, 2013, 08:38:33 PM »
36mm Quad Vent I have on mine is 45, DGJ, 170, about 1.5 on the AS and I have a cut airbox lid located in IN, I would probably start out a bit richer on the main if it were me to be safe on the first plug check. I also have a Pro X cylinder but I haven't seen a huge variance from what I ran with my stock cylinder when I switched over.
