Workshop
Engine and Bottom End
Jetting from 80 deg to 20 deg weather
Topic: Jetting from 80 deg to 20 deg weather (Read 2862 times)
pantera1975
December 06, 2013, 09:30:02 PM »
I have a trx 9 ESR motor in a ATC with a 39 mm Keihin carb. Is it common to have to raise up the needle or use a richer one. How much should I start with changing the slow and main jet?
supernutt
Total likes: 2
December 06, 2013, 09:42:32 PM »
I usually raise the needle 1 clip and up the main jet. Ran a 192 this summer and currently running a 200 in freezing temps. I always figured 1 main size for every 20 degrees in temp change. Never really mess with the pilot...Just the air screw a little..
97 Laeger XC narrow CR500 link +4 t-pin
rk88r
Total likes: 8
December 07, 2013, 10:34:59 AM »
I do about the same as Supernutt. Just raise the needle a clip. I did buy a ecg to experiment with this winter, in the past I've run a dej one up. It's so damn cold now the R is staying in.
Bigred
December 07, 2013, 06:24:24 PM »
I just kick it over and run it lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
The_Steve_Man
December 07, 2013, 06:48:17 PM »
It was 16 here today. No 2 stoke riding today. But very good information
supernutt
Total likes: 2
December 07, 2013, 06:57:46 PM »
I had about 22 degrees and it was awesome!! Went out for a hour ride. No snow and frozen ground. Cant tear anything up and quad really goes on frozen soil.
Workshop
