Author Topic: MSD Ignition.. pros and cons?  (Read 7076 times)
« on: December 24, 2013, 05:00:47 PM »
considering going with the msd ignition and coil setup on my saber. what are the pros and cons of it? also are the benifits worth the upgrade and how much trouble are they to setup?
Hybrid R
Offline TRX250R1
« Reply #1 on: December 24, 2013, 05:33:47 PM »
I know nothing about them but I was talking to my friend Chad who owns Victory Motorsports about a Pilot setup.  He said his MSD misfired and it blew his Pilot cylinder off the bottom end.  Said he's never use them again
Offline atv fan 28
« Reply #2 on: December 24, 2013, 07:53:33 PM »
Hopefully Dave will chime in. He seems to know a lot about ignition set ups.
« Reply #3 on: December 24, 2013, 11:47:43 PM »
Had Msd on a Banshee, seen no real issues
Offline jadleybray
« Reply #4 on: December 24, 2013, 11:49:44 PM »
Quote from: TRX250R1;20671
Sounds like he didn't have the pickup/timing set correctly.  It can be tricky on this setup.  Sean just finished getting his together on the puma, he can elaborate.
Offline johnny22
« Reply #5 on: December 25, 2013, 12:21:01 AM »
I'd like to know also. Talked to matt shearer about my saber and he said its ideal to get one over the cr ignition
Offline seanoktm
« Reply #6 on: December 25, 2013, 11:13:33 AM »
If you want to get to most out of your motor for drag racing msd is the way to go. I took my cr ignition off didn't change anything on the setup put the msd on on gained 500 rpm of over rev.
JDI Racing
« Reply #7 on: December 25, 2013, 12:05:21 PM »
a programmable unit should be alot better than a fixed ign for obvious reasons. i dont know anything specific about the msd but theres several different brands that can fit up to the honda. i think a programable will be one of my next investments pretty soon
Offline seanoktm
« Reply #8 on: December 25, 2013, 12:19:02 PM »
The msd I run is a 4217 msd fully programmable single cylinder ignition. The down side is you have to spend time and money to make the setup work. You need a lab top so you can put different timing curves or adjust the two timing curves you can have in the cdi. I make adjustments at the track if needed. A two stroke timing light is also something you might want.
JDI Racing
Offline BigBlock10
« Reply #9 on: December 25, 2013, 05:21:06 PM »
I think Dana and Bubba are/were running a msd..
« Reply #10 on: December 31, 2013, 08:20:34 PM »
I talked to shearer a while back, he recommended the msd for the saber. said for drag racing the msd is the only way to go.So future plans call for sending my bike to Ryan Hormell at Hormells Extreme Atv in Lafayette. Ill let him order the programmable msd, install it, then dyno tune it to get the max hp and best timing curve out of it..he said its a little trickey to set up initially but once its setup its good to go... guess time will tell..
Hybrid R
