Author Topic: Drag parts, Sphynx 370,Drag pipe,Bottom end,Lectron,slingshot.  (Read 10618 times)
Offline BigBlock10
« on: January 01, 2014, 02:38:26 PM »
Well I'am going to list some of my parts that I have been gathering for a drag build. I'am going to be buying some property to build a new house on, So I'am stepping away form the drag thing for a bit.
All items are OBO, feel free to shoot me a offer on any of the parts. Prices DO-NOT include shipping or paypal fee's
1: Bottom end with new std stroke hot rod crank, was told only a test start on this bottom end. Cases are in excellent shape. No ignition parts(was going to go CR250 ) also comes with a unpainted clutch side cover (no bolts or gasket, was going to have it cut for quick access but did not) clutch hub looks to be billet.$700 OBO
2: A Nate McCoy drag ported sphinx 370 & shearer OOF drag pipe,Cylinder is set up for a 5mm crank and alky, Has been tapped for a alky pump and also has a tap for a nitrous nozzle. This cylinder and pipe were on Nates personal bike. Taken off, updated with new port work and replated (0 run time) New 78mm wiseco piston kit. I would like to sell the topend and pipe together as they are matched for each other. But will split up if they sell at the same time. Was told this setup could make 80+hp. $1700 OBO
3: Slingshot lockup, It has 4 bolts holding the top plate on, I am not sure if these were just put on to hold the plate on during shipping or if you use stock clutch plate bolts. either way not a big deal $250 OBO. (Sold)
4: Marvin shaw comp rear shock 13.5"-14" eye to eye$150 OBO
5: Lectron 44mm carb setup for alky, 2 pj's, billet packard bowl, When I bought this carb I disassembled it to check for stripped,ripped or broken parts, and did not find any. The only thing I would do is re apply sealant around the PJ's.$250 OBO
6: 450r Fireball drag axle, Was going to run this with a 450r swing arm swap.$275 OBO (Sold)
If you have any question or would like more pictures, Feel free to ask. also if you would like to talk over the phone please PM me and I will shoot you my number.Thank you.Derek.
« Last Edit: January 02, 2014, 08:31:23 PM by BigBlock10 »
Offline johnny22
« Reply #1 on: January 01, 2014, 07:59:04 PM »
Pm sent
Offline BigBlock10
« Reply #2 on: January 02, 2014, 10:05:26 AM »
Sale pending on Sling shot.
Thanks
Derek.
Offline puma
« Reply #3 on: January 02, 2014, 10:40:04 AM »
pm send
Offline puma
« Reply #4 on: January 02, 2014, 11:16:06 AM »
pm sent
« Reply #5 on: January 02, 2014, 11:33:21 AM »
I would say that is does make 80hp as it has been dyno'd I believe. But my seat of the pants dyno says it was quick.
Offline BigBlock10
« Reply #6 on: January 02, 2014, 11:56:36 AM »
Slingshot is sold.
Thank you.
Derek.
Offline puma
« Reply #7 on: January 02, 2014, 07:25:14 PM »
pm sent
Offline BigBlock10
« Reply #8 on: January 02, 2014, 08:38:12 PM »
Axle has been sold.
Thank you.
Derek.
Offline BigBlock10
« Reply #9 on: January 03, 2014, 04:08:59 PM »
cylinder and pipe have been sold
Offline Morse250r
« Reply #10 on: January 03, 2014, 08:42:59 PM »
Heard it's staying in Michigan !
88 rb racing duner
Trx 70\'s
Atc 125
Offline BigBlock10
« Reply #11 on: January 04, 2014, 08:29:16 AM »
Quote from: Morse250r;21316
That's the plan. Going to be some fast 250r's on that side of the state...
Offline puma
« Reply #12 on: January 04, 2014, 12:18:23 PM »
pm sent
Offline BigBlock10
« Reply #13 on: January 05, 2014, 09:35:19 AM »
Make some offers on the rest of this stuff, I have no need for it now...
Thanks guys.
Derek
Offline BigBlock10
« Reply #14 on: January 25, 2014, 10:26:17 PM »
Open to offers on all remaining parts.
Thanks.
