Author Topic: JJ&A Axle Question  (Read 4071 times)
Offline Leftynanners
JJ&A Axle Question
« on: January 05, 2014, 03:36:29 PM »
I'm trying to install a JJ&A play axle and I noticed the sprocket hub had a lot of space from the bearing carrier. I know it's supposed to have a bit of space but this seems a bit excessive. I tried to tap it lightly to see if it would go in more but it wont budge. Any ideas what's wrong? Or am I overreacting and this is supposed to be normal? There's also a bit of space on the brake hub as well. I'm not sure if it's normal.
Here's pics of both:
JJ&A Axle Question
« Reply #1 on: January 05, 2014, 04:29:47 PM »
Have you tried to install the rotor and caliper to see if it all lines up? Same with the sprockets and chain? I don't have a JJ&A so I cant be specific sorry man.
JJ&A Axle Question
« Reply #2 on: January 05, 2014, 05:05:20 PM »
I'm eyeballing the hub and it doesn't look like it lines up with the front sprocket at all. I suppose I should actually try installing it and see if it lines up. I'll try it tonight and post an update. Thanks!
Offline atv fan 28
JJ&A Axle Question
« Reply #3 on: January 05, 2014, 06:20:20 PM »
I know it's a stupid question but did you loosen up the bolts on the sprocket and rotor hub before you tried tapping it?
Offline atv fan 28
JJ&A Axle Question
« Reply #4 on: January 05, 2014, 06:30:10 PM »
Never mind....i just went out and looked at mine and it looks just like yours. So i believe you are good to go. :)
JJ&A Axle Question
« Reply #5 on: January 06, 2014, 12:51:21 AM »
Alright cool!! I was spending time with family today and didn't have enough time to work on it tonight. Thanks for checking for me! I really appreciate it!
