Author Topic: BR5ES Plugs  (Read 3524 times)
Offline The_Steve_Man
BR5ES Plugs
« on: January 10, 2014, 07:21:32 PM »
Is there anybody using br5es plugs? We used to run them and seemed to give our bikes more power.  I guess because they are such a hot plug.
 I was at the parts store getting plugs and thought about these.
Offline atvmxr
BR5ES Plugs
« Reply #1 on: January 10, 2014, 09:12:23 PM »
I would maybe use a 7 , definitely not a 5
BR5ES Plugs
« Reply #2 on: January 10, 2014, 09:43:46 PM »
Quote from: atvmxr;21976
A 7 if you were jetted extremely rich!
Offline fast350r
BR5ES Plugs
« Reply #3 on: January 10, 2014, 10:16:46 PM »
I thought you only ran that hot of a plug if your motor is toast , low compression . I use b8es plugs
Shearer 431 puma
BR5ES Plugs
« Reply #4 on: January 11, 2014, 12:57:47 AM »
the plug only needs to be hot enough to not foul when jetted proper.I run a 9 in the dunes running wide open most of the time and have used a 10 for hill racing
Offline ledperformance
BR5ES Plugs
« Reply #5 on: January 12, 2014, 12:48:55 AM »
B7's work great most of the time and give more accurate plug reading. I always use B8's on customers bikes. I have never looked at a B9 that wasn't too cold. We raced MX and TT nationals with B8's.  (and won) We were running 230 - 245 lbs of compression. We never had detonation problems.
BR5ES Plugs
« Reply #6 on: January 12, 2014, 03:17:13 PM »
Quote from: ledperformance;22035
are you referring to reading the ground strap
