Author Topic: Got any tie rod anti seize tips and tricks  (Read 2749 times)
Offline bnau267
« on: January 12, 2014, 12:55:48 AM »
Maybe it's just me but it never fails that at least one of my tie rod ends becomes seized to the point where I destroy something trying to loosen it up.  Please share your secrets....
Offline Bigred
« Reply #1 on: January 12, 2014, 12:59:25 AM »
Vise grips under the top of the boot (close to a arm)
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline bnau267
« Reply #2 on: January 12, 2014, 01:18:36 AM »
Cool.  What about breaking loose the lock nuts (tie rod and tie rod end).  I always assume I'm turning them the wrong direction but I think I got that down by now.  I never fails though that at least one side or the other won't release causing me to adjust toe by removing the whole dang tie rod assembly.
Offline sanddad21
« Reply #3 on: January 12, 2014, 11:32:52 AM »
i use anti seize with copper in it. its pretty hard to find i got mine when i used to drill wells
