Author Topic: Roll XC Shock Length  (Read 6803 times)
Offline bnau267
« on: January 26, 2014, 03:26:48 PM »
Anyone happen to know the shock length for Roll XC's?  The sub zero weather is keeping me from getting my front end put together and this is driving me crazy.  I would run 21" fronts and 20" rears on a OEM spec frame (Arens Bros).  Just curious if anyone did the 12" extended and 1.5" compressed measurement running Roll XC's and 21/20 tires.  I know there are other measurements to worry about but I'm mostly curious about the length right now.
Offline Rockingkfarms
« Reply #1 on: January 26, 2014, 08:32:06 PM »
What time period are your Roll a arms from?
I'm guessing these are standard travel...?
Offline bnau267
« Reply #2 on: January 26, 2014, 08:48:27 PM »
Fresh off the press....2013.  It will be a while before I get a chance to get measurements.
I have Roll +3's and can tell these are defindently closer to standard length.
Offline killer_250r
« Reply #3 on: January 27, 2014, 12:36:10 PM »
I think my lobo uses 17".  I'll check later tonight when I get home for sure.
98 XC Lobo, Ballance racing, LED 350PV
Offline bnau267
« Reply #4 on: February 14, 2014, 05:03:21 PM »
Quote from: killer_250r;23670
Killer - does 16 3/4 sound right?  Paige gave me that number for Elka's.  Assuming it would be the same regardless of brand.
Offline killer_250r
« Reply #5 on: February 14, 2014, 05:47:37 PM »
Yup that's the length on my axis too.
Offline bnau267
« Reply #6 on: February 14, 2014, 05:55:26 PM »
Cool deal - thanks!  Bob
« Reply #7 on: February 14, 2014, 07:44:48 PM »
My Roll arms w/ my Laeger frame use 18.75 inch shocks. So i'd measure them to be absolutely sure. That's with 21" tires as well
Offline killer_250r
« Reply #8 on: February 14, 2014, 08:22:26 PM »
I measured my lobo a few min ago. 16 3/4" and I also run 21" tires. I know roll mx arms use longer shocks like tbone has.
Offline bnau267
« Reply #9 on: February 14, 2014, 09:21:57 PM »
Quote from: Tbone07;25578
You running the MX arms?
Offline bnau267
« Reply #10 on: February 14, 2014, 09:25:31 PM »
Quote from: killer_250r;25582
If I set it up to run 21 tires it won't be that big of a deal if I ran 22's right?
Offline killer_250r
« Reply #11 on: February 14, 2014, 09:36:47 PM »
You will have to adjust your ride height some but I deff recommend the 21" over the 22s
Offline bnau267
« Reply #12 on: February 14, 2014, 10:10:28 PM »
Yeah...seems I got carried away with what the old schoolers ran back in the day when I bought my 22's.  The new school of thinking is certainly 21's.  Guess I'll run the 22's on my stock 89 and save the original stock tires.
Offline killer_250r
« Reply #13 on: February 14, 2014, 10:23:01 PM »
That would be best. 21" turns so much nicer than 22" and suspension has come a long way from back in the day lol
Offline bnau267
« Reply #14 on: February 14, 2014, 10:33:01 PM »
Quote from: killer_250r;25596
That's what I get for checking out in the 90's and returning in the 450 era.  Live and learn.  Maybe I'll do a 250r 4x4 build.
