Author Topic: High Idle  (Read 3984 times)
Offline The_Steve_Man
High Idle
« on: February 03, 2014, 06:55:25 PM »
I just replaced my stator and coil and now I can't get it to idle down.
 It ran fine before the stator went out.  I have an 85 motor with a 39mm PWK.  I have the idle screw all the way in and it still idles way high.
Any suggestions?
High Idle
« Reply #1 on: February 03, 2014, 07:05:32 PM »
Air leak, cable f'ed where it goes into carb?
High Idle
« Reply #2 on: February 03, 2014, 07:07:16 PM »
Stator side seal out and now the cover is off or not sealed up as well as before?
High Idle
« Reply #3 on: February 14, 2014, 06:41:56 PM »
Got it fixed.
Apparently I had weak spark and when i replaced the stator and coil,  I have good spark.
I couldn't figure why it was fine before the stator went out it ran fine and after it had a high idle. I adjusted the idle screw but not enough.  I had to screw it way out from where it was before.
Just trying use my experience (or lack of) to help somebody else.
High Idle
« Reply #4 on: February 15, 2014, 12:19:50 AM »
Glad you're riding man.
High Idle
« Reply #5 on: February 15, 2014, 07:23:54 AM »
time for a plug chop.
High Idle
« Reply #6 on: February 15, 2014, 09:06:13 AM »
Snow is finally gone. Going to be 55 today.  Good day to tune.
