Author Topic: ESR 8 plate clutch kit  (Read 6803 times)
Offline 2strokesforever
« on: July 08, 2013, 02:15:29 PM »
Anyone have any pics yet of this new billet clutch kit that ESR has made. Great price just wondering if there is a catch. http://www.eddie-sanders-racing.com/product_p/esr%208%20basket%20kit.htm
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
« Reply #1 on: July 08, 2013, 02:19:12 PM »
nevermind noticed it requires their clutch cover also already have a Hinson quick change installed on mine
88 TRX250R
Boyesen Rad Valve
« Reply #2 on: July 08, 2013, 02:25:16 PM »
They probably post that as in it wont work with an oem cover. If your hinson cover has the added clearance required is a good question but you might possibly be good. Maybe someone else on here might know more about this or just call them up to see if they know.
« Reply #3 on: July 08, 2013, 02:29:11 PM »
I would call them up and see. I just talked to Tom about 20 min ago. Very helpful fellow.
« Reply #4 on: July 08, 2013, 02:41:53 PM »
their site says
"New 8 clutch basket kit comes with basket inter basket pressure plate all from billet machined here at esr this kit will eliminate clutch slippage needs esr clutch cover"
If that is true thats a hell of a deal if its all billet
88 TRX250R
Boyesen Rad Valve
« Reply #5 on: July 08, 2013, 02:51:52 PM »
rablack21 just noticed your in Soddy Daisy im in Knoxville and ride in Rockwood right past Spring City
88 TRX250R
Boyesen Rad Valve
« Reply #6 on: July 08, 2013, 03:30:06 PM »
Quote from: 2strokesforever;1832
I have heard of people riding up there, but not been there myself. Don't know where the riding area is.  I was just up at I-40 mx track in Lenoir City about 2 weeks ago also.
Offline d-rock
« Reply #7 on: July 08, 2013, 04:52:07 PM »
You should call them . I odered alot of parts from them last year but the clutch kit wasnt ready yet. i called back this spring with the same answer. they are waiting on a broach to finish machining it.
 Derek.
« Reply #8 on: July 08, 2013, 06:39:13 PM »
Quote from: rablack21;1841
i live 10 mins from that track..lol
88 TRX250R
Boyesen Rad Valve
Offline derby
« Reply #9 on: July 08, 2013, 07:36:38 PM »
It might work.  To run the hinson 8 plate setup you had to have the hinson cover.
« Reply #10 on: July 08, 2013, 09:44:55 PM »
true
88 TRX250R
Boyesen Rad Valve
