Author Topic: What do i use to seal up exhaust at flange?  (Read 4021 times)
Offline JoePA
« on: February 24, 2014, 11:23:47 AM »
I purchased that crazy seal the TRL use to sell but once he sold the site to Tony I haven't seen it since. So what can I get to seal the exhaust flange?
« Reply #1 on: February 24, 2014, 11:38:29 AM »
Permatex, High temp silicone. You can get in in Red, Gold & Black.
Dont be afraid to glob it on & once you see any seepage after running for a while, pull the pipe & reseal it again.
« Reply #2 on: February 24, 2014, 11:45:39 AM »
Don't use the high temp Copper stuff whatever you did. HUGE mistake. You will be lucky if the pipe ever comes off again.
Offline JoePA
« Reply #3 on: February 24, 2014, 11:49:32 AM »
Thanks Neil! I have the High temp silicone. I used that on the Sparks pipe and it worked well. I nned something for the flange and should I be concerned where the pipe meets the silencer? Thats not a very good fit either.
« Reply #4 on: February 24, 2014, 12:11:21 PM »
Permatex Ultra Black, clean the flange and pipe of any oil with brake cleaner then apply a thin coating on the pipe end then put a larger amount on the cylinder side flange.
Push the pipe on, wipe away the excess that pushes out and wait a minimum of 3 days or longer, the wait time is the key to it lasting or failing.
On the connection joint of the pipes 2 halves you do have to be careful of it being very hard to remove, but at the cylinder its almost never a issue.
http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex-ultra-black-maximum-oil-resistance-rtv-silicone-gasket-maker-detail
« Reply #5 on: February 24, 2014, 12:30:53 PM »
I run this between the pipe and silencer. Works awesome. Can't beat it.
http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=147&products_id=230
