cylinders and hood ect shop cleanout
Topic: cylinders and hood ect shop cleanout (Read 1468 times)
jfwyatt1
March 01, 2014, 02:37:34 PM »
black cylinder with piston and head came off running engine head has been shaved and has had something bounce around and damage it at 1 time just not with this piston. this cylinder measures 66.24 with a cheap harbour freight dial caliper has a little port cleanup started by someone cylinder walls look good. outside of cylinder has 2 dings but they didnt seem to effect anything or could be easily repaired $80+ shipping . the other cylinder measures 67.5 and needs bore cylinder walls are pretty rough would probably need to be bored to at least 68mm to clean up $40+ shipping
jfwyatt1
March 01, 2014, 02:53:18 PM »
hood looks pretty good i a little warped from the way it was stored but should bolt up fine only has a few lite scratches $20+ shipping the axle is unkown brand maybe durablue? as you can see it has some slight damage where the bearing rides on the sprocket side but it seems to fit to a bearing pretty good needs sprocket hub and keeper $80+shipping the clutch basket and pressure plate is useable $20 shipped last pic is of the $40 cylinder ive never personally used any of this stuff it has come from parts lots ive bought over the years and if im totally off on prices let me know thanks i prefer paypal
Last Edit: March 01, 2014, 03:10:04 PM by jfwyatt1
