Author Topic: LED billet trans available yet?  (Read 23313 times)
Offline ledperformance
« Reply #15 on: March 19, 2014, 11:59:20 AM »
stock ratios, 88/89
« Reply #16 on: March 19, 2014, 10:34:48 PM »
We worked on 2nd gear today. Mocked up a prototype out of aluminum to check the fit and function. A few little tweaks, and then we will build the final steel parts. I expect the gears to go to heat treat by the end of this week. Very exciting to have gears again!
« Reply #17 on: August 18, 2014, 12:14:24 AM »
Gears are go! I picked up my set...now to get the rest of the parts for the bottom end rebuild for the back up motor.
Best regards
-Jason
Offline Bio86
« Reply #18 on: August 18, 2014, 08:22:49 AM »
Are these basically OEM replacements? Same ratios?  Curious what kind of power can be put down through them vs stockers or Yukon even.
McCoy\'d
« Reply #19 on: August 18, 2014, 08:36:27 AM »
yes these are OEM replacement with same ratio but they have more material added to them for more strength
Offline Bio86
« Reply #20 on: August 18, 2014, 08:46:35 AM »
Jeepers creepers, I ended up doing a billet 1-5 override which probably isn't completely necessary for what I'm doing.  Never seen this thread for some reason.
McCoy\'d
« Reply #21 on: August 18, 2014, 10:54:24 AM »
those mccoy 1-5 setups are nice!
