Author Topic: silicone on gaskets  (Read 6174 times)
silicone on gaskets
« Reply #15 on: March 28, 2014, 06:25:13 PM »
Quote from: JoePA;30131
How about on the headgasket?
I've always heard that any type of sealer on any head gasket is not a good idea because when the head get's torqued it can get squeezed into the water passages & affect coolant flow. I've never put sealer on a head gasket though so I can't speak from personal experience weather thats right or not.
silicone on gaskets
« Reply #16 on: March 28, 2014, 07:54:00 PM »
ive used about every kind of rtv that permatex makes and it all works fine. tried honda bond also and it works fine although i dont care for it and havent used it in years mostly because its runny and might cause the gasket to push out if the mating surfaces are not dimpled (had a cylinder and case gasket push out with hondabond). used rtv on metal head gaskets alot and it works great for me. the key is to just use a small amount so it doesnt spooge into all the passages and port tunnels. im sure most any sealer will work about the same, its just a matter of which one you prefer
Offline 312R1
silicone on gaskets
« Reply #17 on: March 28, 2014, 09:22:18 PM »
I never use anything just OEM gaskets.
