Author Topic: silicone on gaskets  (Read 6201 times)
Offline patman13mia
silicone on gaskets
« on: March 28, 2014, 01:40:16 AM »
gona be putting my bottom end back together tomorrow. just wondering what you guys are using on the gaskets when installing?? some kind of silicone compound or maybe a sealant?? id like to know soon that way i can buy this stuff in the am.. i have the day off and its gona be quad filled!!! yippie!!
Offline GO OVRIT
silicone on gaskets
« Reply #1 on: March 28, 2014, 06:08:02 AM »
If everything's clean and flat, you don't need anything but a clean dry gasket.
silicone on gaskets
« Reply #2 on: March 28, 2014, 06:40:00 AM »
I always feel a little more confident, using a small thin consistent bead, of silicone adhesive with the gasket. Necessary? Maybe not. Piece of mind? Definitely! :peaceful:
Offline JoePA
silicone on gaskets
« Reply #3 on: March 28, 2014, 07:24:23 AM »
I use 1211 on all my gaskets.
Offline supernutt
silicone on gaskets
« Reply #4 on: March 28, 2014, 07:28:02 AM »
Quote from: JoePA;30116
Same here!
silicone on gaskets
« Reply #5 on: March 28, 2014, 08:24:30 AM »
^^^ Agreed. I use 1211 as well under the label of Hondabond 4.
Online Tbone07
silicone on gaskets
« Reply #6 on: March 28, 2014, 09:34:29 AM »
I use Permatex RTV silicone on all gasket surfaces. After my last motor leaked oil all over the place from the clutch cover with a brand new gasket I got paranoid.
silicone on gaskets
« Reply #7 on: March 28, 2014, 09:51:42 AM »
I like 1211 also but have used other silicone style sealers, but I put very little on, in fact you really cant tell I have any on the gasket except for the fact that the gasket is shiney.
I apply it using my finger and thumb and just work it in by rubbing it on between my fingers.
For the base gasket I use Loctite 518 gasket maker which is anaerobic sealer, meaning it does not dry unless in the absense of air so the un dryed sealer that pushes into the crankcase area will wash away as the motor runs and the out side can be wiped clean
Offline patman13mia
silicone on gaskets
« Reply #8 on: March 28, 2014, 09:55:07 AM »
Great tips guys.. I'll try some 1211. I'm guessing I have to buy this at an motorcycle shop or would autozone or napa carry it?
silicone on gaskets
« Reply #9 on: March 28, 2014, 10:04:13 AM »
Quote from: patman13mia;30127
Alot of places don't carry Threebond 1211 locally, but most shops usually carry it branded as "hondabond 4" or yamabond. It is the same thing and is made by Threebond, just relabeled.
Offline JoePA
silicone on gaskets
« Reply #10 on: March 28, 2014, 10:25:42 AM »
How about on the headgasket?
silicone on gaskets
« Reply #11 on: March 28, 2014, 10:30:17 AM »
I don't put it on the head gasket, for oring type or original multi-stack metal gasket. Not sure how others do it.
Offline JoePA
silicone on gaskets
« Reply #12 on: March 28, 2014, 10:33:54 AM »
I used 1211 once. it didn't hurt anything but can't say if it would keep a cool head from leaking either.
Offline patman13mia
silicone on gaskets
« Reply #13 on: March 28, 2014, 10:50:32 AM »
I used hondabond before when I was running the thin cr head gasket.. Sealed up real nice.
silicone on gaskets
« Reply #14 on: March 28, 2014, 06:01:00 PM »
Three things a 2 stroke owner should have in their tool box.
#1 a pressure tester
#2 a tube of Three Bond 1104 sealant
#3 a tube of Three Bond 1211 sealant
Like stated, that piece on mind is worth a whole lot.
You can find the Three Bond on E bay or google for the closest place to you. Auto parts, most dont have a clue what it is.
