Author Topic: Hill shooter chassis  (Read 9089 times)
Offline Honda863
« on: March 29, 2014, 09:56:11 PM »
Hey all I've kinda been a lurker here for a while and thought I would share my new chassis I am building. It's going to be a +8 in front with a +12 swingarm single a-arm all built from 4130 chromoly. I am building the whole thing from scratch will post more as the build progresses. Let me know what you think, any advice appreciated.
« Reply #1 on: March 30, 2014, 08:01:10 AM »
Very cool!  Dual a-arm I assume?
Offline Honda863
« Reply #2 on: March 30, 2014, 09:53:09 AM »
Quote from: havinnoj;30239
Thanks, I'm going to try a single a-arm setup first, if I can't keep it under control I might change it two a double setup.
« Reply #3 on: March 30, 2014, 10:37:42 AM »
IMO you will want to keep the motor mounted as low as possible so you can keep the swing arm pivot bolt low and keep the swing arm as level as possible yet set the bike up with enough ground clearance for the whoops. The more level the swing arm, the less wheeling
« Reply #4 on: March 30, 2014, 10:43:17 AM »
and by the way welcome to the forum and nice build you have started!
Offline Honda863
« Reply #5 on: March 30, 2014, 04:49:59 PM »
Yeah I'm keeping the pivot point parallel with the front sprocket and going to keep as low as I can with the 25" tires I'm going to run. The swing arm should be fairly flat with the exception of a little suspension movement it will have.
« Reply #6 on: March 30, 2014, 10:37:44 PM »
25" tire, must have some power going in that ride ;)
Offline Honda863
« Reply #7 on: March 31, 2014, 09:14:38 AM »
I guess I should have said I am putting a 431 puma in it!!
Offline Mr250sx
« Reply #8 on: March 31, 2014, 12:29:36 PM »
Nice work!
Offline Honda863
« Reply #9 on: March 31, 2014, 10:29:28 PM »
Thanks
Offline Morse250r
« Reply #10 on: April 01, 2014, 07:45:12 PM »
Looks good ! Where will you be mainly ridin at?
88 rb racing duner
Trx 70\'s
Atc 125
Offline Honda863
« Reply #11 on: April 01, 2014, 08:18:48 PM »
I mostly ride the Oregon dunes and here in Washington there are a few small dunes to ride. Hoping to get it to the track a few times this year in Albany OR also.
Offline T8R6X
« Reply #12 on: April 01, 2014, 10:33:53 PM »
where in washington are you?
Offline Honda863
« Reply #13 on: April 01, 2014, 11:18:32 PM »
I'm in enumclaw it's about an hour southeast of Seattle not sure if your familiar with it
Offline traxman
« Reply #14 on: April 01, 2014, 11:24:17 PM »
Are you the guy with Cory's old three-wheeler chassis?? Last time I saw it, it was orange and white. Very nice start by the way..
