Author Topic: 86 front spindle upgrade?  (Read 6537 times)
Offline JoePA
« on: April 01, 2014, 08:02:21 AM »
Well, It's about time I upgrade the front spindles on the old 86. The one caliper is starting to hang up on me again and think it's time to end their racing career. I was thinking of getting the 04-05 450R complete setup or would it be better to just find a good set of 88-89 front spindles, hibs and calipers?
« Reply #1 on: April 01, 2014, 08:32:55 AM »
The 450 or 400ex both add 1/2" in width. I personally love the 250r calipers, but many swear by the 400ex. I am sure the 450's are fine too. Its really up to you. I'd say get whatever you can get the best deal on.
Offline JoePA
« Reply #2 on: April 01, 2014, 09:36:34 AM »
400ex won't work as they add way to much positive camber that i can't adjust. maybe if I had 400ex arms but I tried that the first time i got the R. I'm ok with width as I'm running +3 arms and it's still under 50" with 3:2 wheels.
Anyone running the 04-05 450R spindles?
« Reply #3 on: April 01, 2014, 09:58:30 AM »
what arms are you running that you cant adjust the camber to where it needs to be? Just curious for future haha.
Offline JoePA
« Reply #4 on: April 01, 2014, 10:00:42 AM »
Burgard. I had the top joints all the way in and I had like +1 camber. It sucked cuz i had them all cleaned up, powdercoated, new brakes. It sucked! LOL
« Reply #5 on: April 01, 2014, 10:03:26 AM »
damn....super bummer! lol
Offline Iceracer
« Reply #6 on: April 01, 2014, 02:38:48 PM »
Joe, cut off the pivots on the uppers and have them re worked for the spindles you want to run, can put on new pivot tubes or go to Heims. Just gonna mess up your powder. Or you could make a lower camber shim, all it is a is a washer to push out the bottom to correct the camber, we do it all the Time for LT 250R s
Offline Dirt man
« Reply #7 on: April 01, 2014, 10:17:46 PM »
I can't speak for sure till I take measurements, but I have recently researched that the 04/05 spindles are the same width as 88/89 250r. Also the best geometry with the weight savings in the spindles with a two piston caliper.
It goes fast over bumps too!
Offline DnB_Racing
« Reply #8 on: April 02, 2014, 12:09:11 AM »
there are many threads on atv riders about the 04/05 spindles and breaks and hubs...
the +06 will also work but you would need adjustable upper arms to get a good camber angle,
here is a price quote from zedicus after he did this
heres the list for a 450r front end on a 250r not counting brake pads an sum lil misc stuf... this is a very nice upgrade
 51210-HP1-000 - KNUCKLE, R. FR. - $65.66 - 1
 51260-HP1-000 - KNUCKLE, L. FR. - $65.66 - 1
 45150-HP1-006 - CALIPER SUB-ASSY. L - $40.31 - 1
 45250-HP1-006 - CALIPER SUB-ASSY. R - $40.31 - 1
 44311-HN6-000 - COLLAR, WHEEL SIDE - $3.96 - 2 - $7.92
 44313-HN1-000 - COLLAR, WHEEL SIDE - $3.49 - 2 - $6.98
 44615-HP1-000 - HUB SUB-ASSY., FR. - $146.21 - 2 - $292.42
 90102-KV3-700 - BOLT, FLANGE (8X28) - $1.81 - 4 - $7.24
 90105-MBB-000 - BOLT (8X24) (Brake rotor bolts) - $3.11 - 6 - $18.66
 Total $545.16
 -use 400ex or 450r rotor bolts
 -400ex/250r hubs dont work
 -250r tie rods can be used but will be adjusted way out
 -ball joints all did fine.
 i picked up a good condition complet setup used for 250$
« Reply #9 on: April 02, 2014, 06:45:08 AM »
Joe, go over to TRX450R.ORG Guys are always parting out all years.
For example, one that is posted now.
06+
-Spindles..$55
-Hubs and rotors..$55
-Front Calipers..$60ea set
Offline JoePA
« Reply #10 on: April 02, 2014, 07:18:25 AM »
Thank you gents!! I'm going to try the 04/05 setup. I found a complete set up cheap so lets see how it works out.
« Reply #11 on: April 02, 2014, 08:10:42 AM »
Quote from: JoePA;30555
Interested in the feedback after you do this!
