Author Topic: flywheel key  (Read 3467 times)
Offline 2k1lvr
flywheel key
« on: April 09, 2014, 07:37:29 PM »
thought i lost the key then found one but not sure if its the right one. does the the flat straight side have a notch cut in it that runs the whole length of it? if it is the right one does it matter if the notch faces the front or back of motor? thanks!
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
flywheel key
« Reply #1 on: April 10, 2014, 08:32:40 AM »
there is not a notch in the flywheel key from the facory, either it is worn from a loose flywheel, someone has files on it or it is a offset key to add timing to the motor
offset flywheel keys look like this
if you have a offset key then you want the key so it is moved to the left(counter clockwise), that would advance the ignition
another pic of a offset key
Offline 2k1lvr
flywheel key
« Reply #2 on: April 12, 2014, 06:03:35 AM »
thanks! i think it was from a 400ex i had years ago. i went by the dealer and they had a new one in stock thanks!!
