Author Topic: plug chop  (Read 3450 times)
Offline aberegg05
plug chop
« on: April 19, 2014, 07:15:12 PM »
Tell me what you guys think I need to change. Suggestions?
Offline DnB_Racing
plug chop
« Reply #1 on: April 19, 2014, 07:56:26 PM »
Quote from: aberegg05;31890
use a new plug and post results old used plugs show too many varables
Offline aberegg05
plug chop
« Reply #2 on: April 19, 2014, 08:10:30 PM »
plug chop
« Reply #3 on: April 23, 2014, 11:25:21 AM »
The plug on the left is operating slightly cooler than the spark plug on the right and there does not appear to be any detonation occurring.  That is ALL that can be concluded!!!!!!!!
A spark plug cannot tell you if you have the jet in the carb that is making maximum power.  You have cut off the part of the spark plug that tells me if the combustion temperatures are in the ball park when the jetting is in the RANGE of making maximum power.
You need to devise a method for gauging performance while testing different sizes of main jets so that you can determine which jet makes the most power......then monitor the spark plug for signs of detonation and the proper heat range for your riding style and conditions.
« Last Edit: April 23, 2014, 07:42:21 PM by Jerry Hall »
