Author Topic: Water outlet gaskets for a CPI cyl  (Read 3961 times)
Offline ccaiazza
« on: May 01, 2014, 06:56:53 PM »
Just like title says looking for gaskets for CPI cl water outlets don't really want to use rtv
« Reply #1 on: May 01, 2014, 10:33:06 PM »
do you have a local gasket house ?  most likely they will give you a small scrap piece for free. i have bought larger pieces but sometimes they give me the scrap for free. was just there today actually so i can make more base gaskets. klingersil green is the best stuff ive found . hell if you pm me your adress ill just send you a piece and cut it out with scissors. seems like i have .018 and .030 thickness on hand right now
Offline kb250r
« Reply #2 on: May 01, 2014, 11:45:10 PM »
X 2 on cut some i dont even think any have ever been made that im awar of coyld be wrong....ive yet to ues any on the puma,been using permatex no leaks yet..
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline Wes350x
« Reply #3 on: May 02, 2014, 07:11:55 AM »
I used 1211 sealant on mine when I had a sphynx and worked fine.
1988 250R
« Reply #4 on: May 02, 2014, 10:31:37 AM »
they dont sell them, but Cometic could make them if you really want them or go to auto zone and buy a roll of gasket material and cut them yourself. But most everyone I know just uses a good silicone, I like the Ultra Gray from permatex because it matches very good to the cylinder if a little squeezes out
« Reply #5 on: May 02, 2014, 11:24:04 AM »
I did not know what you were asking in the PM. I think you wanted these?
Offline ccaiazza
« Reply #6 on: May 03, 2014, 08:13:20 AM »
Yup thats what i was asking for.  Do you make these /sell these if so i need 4, 2 xtra in case.
« Reply #7 on: May 03, 2014, 10:10:28 AM »
Quote from: ccaiazza;32969
I made these on the water jet back when the water outlets were not yet available. I cut 1" aluminum to an L shape with 2 mounting holes. Pete at hybrid bored the holes in the plate and turned one end into a spigot. This was the birth of the water outlets available today when you buy your cylinder. I bought a sheet of .030 gasket material 12" x 18" and sandwiched it between 2 thin sheets of aluminum. I used the pattern from the water spigot to make the ones in the picture.
You can paypal me $3 to print a shipping label and I will send them to you. Thanks, Tony
Offline ccaiazza
« Reply #8 on: May 03, 2014, 04:10:56 PM »
Tony, i need pay pal info
« Reply #9 on: May 03, 2014, 10:33:11 PM »
Tony I wonder if you can purchase the rubber coated stainless like cosmetic uses that should be easier to water jet than gasket material and they could be reused. I would be interested in those
« Reply #10 on: May 03, 2014, 11:18:36 PM »
Quote from: rsss396;33011
I got you. Don't know if they would want to make these as they are only a few to be made. Yes the heavier reusable gasket material would be much easier to cut. Its pretty funny when you realize I am cutting the gaskets with water and they get soaking wet.
