Author Topic: Post your quad & dyno sheets  (Read 12355 times)
Offline Morse250r
« Reply #15 on: May 20, 2014, 10:07:38 PM »
Red is a 310 blue is a stock top end  maybe a 253 ? One size over
Dune port
40.5 Kehin
Cr ign
V force 3 reeds
Trx 5 cm pipe
Race gas
The 310
Dune port
Oem ign
Oem reeds
Trx 5 reg mount pipe
Pump gas
« Last Edit: May 21, 2014, 07:14:49 AM by Morse250r »
88 rb racing duner
Trx 70\'s
Atc 125
Offline Morse250r
« Reply #16 on: May 20, 2014, 10:09:54 PM »
363 pro x alky
88 rb racing duner
Trx 70\'s
Atc 125
Offline Bigred
« Reply #17 on: May 20, 2014, 10:32:06 PM »
What kinda compression and carb was on that stock jug and port job lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Morse250r
« Reply #18 on: May 21, 2014, 07:13:53 AM »
Not sure on the compression
I edited the post to reflect mods
88 rb racing duner
Trx 70\'s
Atc 125
Offline Cellison
LED Sphynx non PV 350 Dyno
« Reply #19 on: May 22, 2014, 09:07:07 PM »
DYNO
My laptop crashed so I don't have access to post what I really think is useful (overlaying 2 different setups to show the difference).
The software used to show the dyno is the old school version of Winpep but none the less you get the idea.
I had originally dyno'd it using a 38AS. Arlan and I decided to "play around" and taper bored the carb out to a 41.5. Jetted with a CEJ needle 3rd clip, 52 pilot and a 180 main. We saw the power shift ~250-300rpm scooping out the bottom and mid but produced 2 HP extra on the top. We all like big numbers but I assure you that was ABSOLUTELY the wrong way to go. In fact I just switched back to a 38AS. Nature of the beast my friends, the larger the carb you lose down low and gain up top. 38AS is magic - leave it alone. Arlan was doing R&D on his 350G pipe. The one pictured is the first release candidate. Was really cool watching my bike build more and more power as Arlan worked his magic on it. It was about a weeks time every night getting emails with dyno results. One of my fondest memories for sure.
Bottom line, IMHO the HUGE benefit of having a builder like Arlan that also makes pipes is the combination is killer. Unlike most companies who talk a big game, he is certainly one of the few that can backup his claims with dyno's. Yes, some people (and a few companies) will say dyno's are a waste or can be cheated. Well, some what true - that part about falsifying info anyway. For instance doing a dyno pull while the motor is cold can get ya a couple ponies. But I will say after using Winpep myself, there are no "cheats" within the software. Let's put that rumor to rest right now.
And another thing I'd like to mention, where I live (Portland Or.) we jet our bikes for 0-500. So you compare my bike to a bike dyno'd in (let's say) Idaho - there's a HUMONGOUS difference and not for the better. The altitude difference is a power killer. Less air + less gas ='s less HP.
Offline Sand_Blaster
« Reply #20 on: May 22, 2014, 11:26:01 PM »
Thats some good numbers Morse! I think I'll get a ESR9 exhaust & maybe a 38mm carb & I will have Arlen tune it properly on his dyno here soon.
87 Trx250r & 99 Banshee
« Reply #21 on: May 23, 2014, 08:44:34 PM »
I am happy with that stock top end, it hits HARD! However i struggle to find much power on the low end, which is fine with it being strictly a duner R, but would still be nice when riding with the wife, or trying to do a long wheelie(like i said, it hits hard and i've gone over backwards a time or two). The 310 on pump gas surprises me. Tempts me to give mine a shot....
